Bad terribly annoying no good three way coolant valves
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Deveak, Jun 15, 2025 at 10:33 PM.
  1. Deveak
    Deveak New Member
    Sunday
    West Virginia
    I use my Prius for gig work so it gets a lot of miles. Recently I got the p1121 code and ignored it because I read on various forums it wasn’t important and most likely a stuck valve. A few weeks later it turned into p1122 and a red triangle. Luckily I just set out and was only a few miles from home. I drove back slow, mostly in EV and downhill.
    Turned out the three way valve internally failed at the rotary seal and leaked all of my coolant out. Many a hot and sweaty hour later I replaced it with a 4 season third party valve and it’s working again but I can occasionally hear the sound of it hunting from
    The sensor being out of sync or whatever you want to call it. Is it a bad valve or just not very good? If it is a failing part, would it fail catastrophically like last time or can I just keep driving it with the code if it pops up again? I need it for work.
    51,019
    there's no way to know, but we have seen a lot of problems with aftermarket (cheap chinese) counterfeit parts. recommendation here is to buy oem from online toyota dealer of brick and mortar.
  3. Tombukt2
    Tombukt2 Senior Member
    12,000
    2,121
    Durham NC
    I have one gutted right now I want to set it in the Midway point so all three ports just stay open pull out motor or driver gear. So motors on nothing moving. Close up install . See what goes down
