bad to leave plug in after charging complete?
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by the_chinadian, Nov 15, 2012.
  1. the_chinadian
    the_chinadian New Member
    35
    Sacramento, CA
    Hi all,
    noob question - is it bad to leave the plug in after the charging is complete? Does it negatively impact the battery or the life of the battery?
    Thanks.
  2. jmlarence
    jmlarence New Member
    27
    Rhode Island
    Wondering the same thing. Using a Kill-a-Watt meter at the outlet and watching variations in amps drawn and kWh for each charge. When the charge is done, there's still a trickle charge of +/- two watts going to the car.
    So it's a good question. Even when the charge is "done" it's not entirely until you unplug...
  3. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    probably the led on the brick is the culprit
  4. ny_rob
    ny_rob Senior Member
    1,968
    813
    L.I.- NY
    The 120v source is disconnected via internal relay once the charge is complete- so no harm in leaving the cordset connected to the car after charging is complete.
    the_chinadian and lensovet like this.
  5. jmlarence
    27
    Rhode Island
    "probably the led on the brick is the culprit"
    Cheers! Makes perfect sense!
  6. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    I soh smart:D:LOL::ROFLMAO:
  7. the_chinadian
    35
    Sacramento, CA
    i figured there was an automatic shut-off, but just thought I'd check with those of you in the community who have the owner's manual memorized ... :p
  8. devprius
    devprius /dev/geek
    979
    291
    San Francisco Bay Area, CA
    I wouldn't say we have the manual memorized, but just lots and lots of experience with this specific part of the car.
  9. 3PriusMike
    2,963
    2,314
    Silicon Valley
    It's more than the LED. There is a circuit in there that detects when you plug in to the car and then negotiates the charging rate, etc.
    Mike
  10. Electric Charge
    Electric Charge Active Member
    545
    133
    Syracuse, NY
    I can confirm that it is the brick consuming the power, as I measured the same thing with my meter without the EVSE plugged into the car. I'll have to do the math, it might be useful to automate a wireless relay which shuts off the outlet when not in use.
  11. the_chinadian
    35
    Sacramento, CA
    My apologies. I was just teasing. I hope I didn't offend you. The forum has been invaluable to me.
  12. devprius
    devprius /dev/geek
    979
    291
    None taken. We're glad to help.
