Bad Transmission Plus Bad Hybrid Battery And 12V
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by TobeyThe2008Prius, Feb 13, 2021.
  1. TobeyThe2008Prius
    TobeyThe2008Prius New Member
    Bel Air MD
    I Have The Prius 2008 Green With 139,892 Miles After About 50 Seconds After Starting The After Letting Sit For 1 Month All The Lights Came On. I Had The Tire Light For 2 Months. I Took It Over To My Friend Who Had Techstream. I Am Wondering Why My Transmission Failed. I Looked Up About The Hybrid Battery And They Fail From Sitting Which I Was Unaware Of. So I Want To Know If This Car Is Worth The Fix I Had It For 13 Years.
    P0A92 521
    P0A7A 344
    P3000 123
    P3015 123
    P0A80 123
    C1241 41 84
    C1259 58 150
    C1310 156 51
    C2122
    B1421
    B1630
    B1635
    12V At 11.02 OFF 13.92 ON
    BB1 15.59
    BB2 15.48
    BB3 15.58
    BB4 15.55
    BB5 13.70
    BB6 15.51
    BB7 15.62
    BB8 15.54
    BB9 15.60
    BB10 15.49
    BB11 15.65
    BB12 15.53
    BB13 15.42
    BB14 15.57
    ALL RR 0.20
    51,994
    charge the 12v and repeat the test if it holds a charge. otherwise, replace it.
  3. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
  4. rjparker
    rjparker Tu Humilde Sirviente
    10,166
    6,319
    Texas Hill Country
    How do you know the transmission is bad?
    What Is Wrong With Your Caps Key?
    As we said in your other posts the 12v battery voltages are low both off and running.
  5. TobeyThe2008Prius
    Bel Air MD
    So I need to replace 12v before I do anything else
  6. mr_guy_mann
    mr_guy_mann Senior Member
    4,048
    1,975
    NJ-USA
    Yes, having a strong 12V battery is the first step to seeing what is actually wrong with your car. It is still very possible that you have a failing HV battery as well. Won't know until you start doing something to check it out.
    Whether or not it's worth fixing is up to you and how much time effort and money you're willing to invest in your car. If you have DIY skills and attitude (and have space / tools to work on things) AND aren't phazed by the thought of making a mistake or having a car that could fail again at some point, then you could repair the HV battery yourself. (this can cost the least money but takes the most time, how reliable this will be depends on how well you do things)
    If you have to pay a shop or dealer to repair your car (ie installing NEW battery modules) then fixing an old prius becomes less feasible. (most money but least time, the new HV battery should be good for another 10 years)
    In between those options is getting NEW modules (from Toyota or Newpriusbatteries.com) and installing them yourself.
    Generally most here do not reccomend any form of rebuilt or refurbished or "repaired" battery since these are made up of used modules that may or may not have been "reconditioned". Reliability is often poor with repeat failures within a few months.
  7. TobeyThe2008Prius
    Bel Air MD
    I got 12V installed at 12.99V OFF And 14.59V ONfrom the dealership and the hybrid Battery bad still. The transmission codes are only pending now.
    #7 TobeyThe2008Prius, Feb 14, 2021
  8. bisco
    51,994
    'newpriusbatteries.com'
    Raytheeagle likes this.
  9. Raytheeagle
    Raytheeagle Senior Member
    11,265
    15,520
    Bay Area, California
    2019 Prius Prime
    @2k1Toaster (y).
  10. strawbrad
    953
    1,007
    Here is the trouble shooting procedure for the P0A92 521 code. The two possible outcomes are replacing the transmission or the inverter. Replacing the inverter takes just a couple of hours and they can be purchased for less than $100. So that repair is not a car killer. Having to replace both the HV battery and a transmission exceed the value of your Prius.
    Your car is worth $500 to $1000 in it's current condition. Someone would be able to DIY the repairs and have a good cheap car. Original equipment catalytic coverters are also scraping for over $1000. That might be a good way to get more money out of your car.
    https://share.qclt.com/%E4%B8%B0%E7%94%B0%E6%99%AE%E7%91%9E%E6%96%AF%E5%8E%9F%E5%8E%82%E8%8B%B1%E6%96%87%E6%89%8B%E5%86%8Cpdf%E6%A0%BC%E5%BC%8F/repair%20manual/04pruisr/05/21bpm/0a92521.pdf
  11. ttou68
    ttou68 Active Member
    351
    211
    From the info, I can see that block 5 (BB5) is the cause of your hybrid battery issue...
    I would start there, if you are able DIY ..
    Good Luck!
