Balance charger recommendations for people on a budget?
Discussion in 'Newbie Forum' started by kibbles510, Feb 18, 2017.
  1. kibbles510
    kibbles510 New Member
    Sf
    Hello,
    I wanted to balance the modules on my Prius pack but I am on a tight budget. Anyone know of a cheap charger that will get the job done?
    49,501
    see this thread. 'Gen 2 prius individual battery module replacement'.
    RCO likes this.
  3. Prodigyplace
    Prodigyplace Senior Member
    11,696
    11,318
    Central Virginia
    Many users here have liked the Prolong system. They are active on PriusChat too.
    Prolong™ Battery Reconditioning Package
    I am not sure if $450 is within your budget, but it is much less than a replacement traction battery.
    fotomoto and RCO like this.
  4. jerrymildred
    jerrymildred Senior Member
    11,511
    14,113
    Tampa, FL
    I second that motion. Not exactly cheap, but it works extremely well. I wouldn't use something cobbled up to maintain a battery as expensive as the Prius battery. It will almost certainly pay for itself.
    RCO likes this.
  5. bisco
    49,501
    some use simple hobby chargers. it's a long slow process.
  6. jerrymildred
    11,511
    14,113
    Tampa, FL
    Sounds like a huge job that way. Any idea how long it takes?
  7. bisco
    49,501
    a couple of weeks i believe. before the grid chargers, pro's were using multiples. but i have only read about it, not tried it myself.
    some have money, some have time, some are sool.
    RCO and jerrymildred like this.
  8. kibbles510
    Sf
    Ok Heres the new voltage on the modules after they've been sitting for about two weeks.
    I also just bought a UltraPower 120AC charger with 2x120w output. Can someone give me specs on what to set the discharge and charge rate for each cell and which cells to start with and which ones to not bother with? Or should i do each cell?
    1.7.60
    2.7.74
    3.7.66
    4.7.71
    5.7.71
    6.7.73
    7.7.69
    8.7.72
    9.7.74
    10.7.72
    11.7.71
    12.7.68
    13.7.69
    14.7.72
    15.6.43
    16.7.67
    17.7.73
    18.7.71
    19.7.71
    20.7.71
    21.7.71
    22.7.76
    23.7.76
    24.7.65
    25.7.73
    26.7.73
    27.7.76
    28.7.64
  9. Sam Spade
    Sam Spade Senior Member
    2,036
    1,023
    2017 Prius c
    There are a LOT of better things you can do with your money if you really are on a "tight budget".
    Trying to do this on the cheap might do more harm than good.
    RCO likes this.
  10. jdenenberg
    jdenenberg EE Professor
    3,852
    1,852
    Trumbull, CT
    2020 Prius
    LE AWD-e
    Module 15 is trash as it has a shorted cell. You need to load test the others to see if any of them drops to a lower voltage than the others.
    JeffD
  11. fotomoto
    fotomoto Senior Member
    5,602
    3,779
    So. Texas
    Well it's obvious that #15 is the weak module. That it's in the middle of the pack doesn't surprise me either.
    I use a grid charger on the whole pack at once (plug in and walk away) so I don't have any advice on doing it individually. That method is from the early days and most of those folks have moved on but there should still be a few here with some good advice.
    After repairing a pack, you need a periodic (monthly) conditioning to keep it healthy. That's impossible from a practical standpoint with what you have now. You also need a way to load test those modules to see if they fail under load (or show signs) and not just resting voltage.
    GOOD LUCK!
