Bank 1 o2 sensor replacement?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by eatdrumss, Mar 10, 2022.
  1. eatdrumss
    eatdrumss Junior Member
    57
    cleveland
    Is it okay to just replace bank 1 that is throwing a code or should I really consider replacing both banks at the same time?
    Also are they both the same part?
  2. PriusCamper
    PriusCamper Senior Member
    13,018
    5,290
    Pacific Northwest, USA
    Maybe clean and inspect both of them first and then when code comes up again decide?
  3. eatdrumss
    57
    cleveland
    I could replace bank 1 and then clean the old one for later use? ....[as needed]
    How would I clean it off?
  4. JC91006
    16,827
    8,600
    The downstream 02 sensor would be the one causing the code. It's fairly cheap for the OEM Denso on Amazon, less than $50.
    But most of the time, the code is caused by a bad Catalytic converter
  5. eatdrumss
    57
    cleveland
    Code says bank 1 upstream...p2196....also others have had the same issue after replacing an engine.
    Is it correct there are 2 upstream sensors and 1 downstream on the 2010s..?
  6. PriusCamper
    13,018
    5,290
    I'm way more willing to believe someone's claim of a faulty upstream sensor compared to someone's claims of a faulty downstream sensor.
  7. PriusCamper
    13,018
    5,290
    I'm way more willing to believe a faulty upstream sensor compared to someone a faulty downstream sensor.
  8. PriusCamper
    13,018
    5,290
  9. PriusCamper
    13,018
    5,290
  10. JSB_99
    JSB_99 Member
    66
    48
    Houston
    don't be surprised if changing one or both don't fix the problem.
    There is only one up and one down.
