Bars leak in small pieces of foam to seal coolant leak
Discussion in 'Gen 2 Prius Technical Discussion' started by lech auto air conditionin, Aug 17, 2019.
  1. lech auto air conditionin
    830
    605
    261
    san francisco
    Water heater pump plugged E5FA056A-D1F5-468E-9E3A-9135ECB5AC88.jpeg A3BBA294-9A54-4F0A-B8FF-371CC43AE642.jpeg
  2. Fliebly
    Fliebly New Member
    22
    Tx
    I found the black foam in my heater pump too! What's causing that?
  3. dolj
    dolj Senior Member
    8,461
    4,297
    Wellington, New Zealand
    If you listen to the two guys talking in the video, they seem to be fairly sure it is a product called "Bars Leak[s Stop]".
    Funnily, when I was reading your post, I was wondering what kind of crud a radiator stop leak would create, after all, there has to be some kind of material to plug up the leaks, right?
  4. lech auto air conditionin
    830
    605
    261
    san francisco
    what people do not understand is that with today's new high efficiency radiators/heater cores/ condensers the new small opening (holes) for fluid passage are so small any thing can plug them maybe not all of them but will semi clog your heat exchanger. when I was in GM class in the early 90's we had cutaways of different heater cores with coolant passages so small a BIC ball point pen ball bearing will clog it.
  5. Fliebly
    Fliebly New Member
    22
    Tx
    Bars leak were the the little pebbles he picked up. The foam is something that is deteriorating inside. I have seen other posts of others having the same issue. I haven’t used a stop leak in my Prius. I was asking about the foam that is showing up in mine and others Prius’.
  6. valde3
    valde3 Senior Member
    2,002
    750
    Finland
    You're sure? I think they thought that both copper colored stuff and black foam stuff was stop leak. There are many different stop leak products with different stuff in them and none of them should be used in a Prius.
