Base or Touring model...differences?
Discussion in 'Gen 2 Prius Main Forum' started by sea-horsea, Aug 2, 2007.
  1. sea-horsea
    sea-horsea Junior Member
    97
    the only few things I found about the 2 models are tuned suspension, Headlights, and 1" more on the wheels for the touring model. Is it worth it? I mean what differences does it make between the 2 models?
  2. Tideland Prius
    16,445
    and a longer rear spoiler (Type B).
    Depends on the package. In some cases, it's only a few hundred more. IT's best to try both and see which suspension you like.
  3. catgic
    catgic Mastr & Commandr Hybrid Guru
    586
    140
    HTTP 404 Not Found
    HTTP 404 Not Found
  4. Pinto Girl
    Pinto Girl New Member
    3,093
    350
    There's not really that much of a difference between the two...if you're flexible, go for whichever one you can get the best deal on!
    Some people say that the Touring gives "somewhat better handling" while others say it's got "a somewhat bumpier ride."
    If you're thinking about taking the wheel covers off of the Touring wheels, though, they have kind of a brushed finish that might look better with certain body colors.
  5. rigormortis
    rigormortis Active Member
    1,340
    26
    san jose, ca
    touring has:
    1) HID headlamps + fog lamps (standard)
    2) larger rear spoiler, i would disagree on 'slightly larger', its gotta stick out at least 3 inches
    3) larger tires and ALLOY wheels (base has steel wheels)
    4) european suspension
    5) harder to find + less of them! heh
