Basic addon Subwoofer for an '08 with JBL...
Discussion in 'Gen 2 Prius Audio and Electronics' started by grinthock, Feb 23, 2010.
  1. grinthock
    grinthock New Member
    I am happy enough with the JBL setup that's in the car now.. However I would like to add a subwoofer to the existing setup..
    I know there are a bunch of different wiring pinouts across various years...
    from what I am seeing, I should be able to grab the line IN from the amp, and a trigger, send it to a small sub box in the back and be in business -- correct?
  2. KK6PD
    KK6PD _ . _ . / _ _ . _
    4,003
    944
    118
    Los Angeles Foothills
    I have a Gen II, and I also felt the Bass lacking. Check out my solution and fix in this thread. Read post #37!!
    http://priuschat.com/forums/gen-ii-prius-audio-electronics/42592-subwoofer-location-4.html
    It adds just enough to make my HAPPY!!!
    $99.00 at Amazon..
    http://www.amazon.com/dp/product/B000OSZA44?tag=priuschatcom-20 your amp under the passenger seat. If it has 3 plugs it's a 2009 JBL Amp. If it has only 2, that would e a 2008 Amp. I have a 2008, with a 2009 amp.. PM me if you want a PDF copy of the Electrical Schmatics. I have copies of both years!
  3. grinthock
    KK6PD de VE3UDP..... (Glad to see lots of other ham's on here)
    That's the perfect solution to be honest... I used to be a HUGE audiophile, and I love some of the tuning options people are using here and signal summing systems -- there was a time when I would go that way - no question...
    That looks perfect... Just need to find one here in Canada. Thanks for the offer for the schematics - if you could send them both to me that would be great, my username at gmail.
  4. KK6PD
    4,003
    944
    118
    RYRYRYRYRYRY
    VE3UDP de KK6PD
    You have mail, let me know if it arrived OK!
    KK6PD
    -30-
  5. pri2b
    pri2b Junior Member
    52
    left coast
    Is there another place that subwoofer will fit besides right in the middle of the cargo area?
  6. KK6PD
    4,003
    944
    118
    Where ever you can fit it!!!! In the tire well, on the back of the rear seat, it's not that big of a unit, in fact it's one of the smallest you can get!!! Use your imagination!!!
  7. dony71
    dony71 Junior Member
    californica, usa
    @KK6PD : your boss audio BASS-600 input is connected to high input (speaker) or low input coax cable?
  8. KK6PD
    4,003
    944
    118
    I used the speaker out Hi Level!!!
  9. NCPRIUSGIRL
    NCPRIUSGIRL New Member
    WILMINGTON, N.C.
    Would that fit in the little storage section under the catgo space? And if so how would it sound
  10. KK6PD
    4,003
    944
    118
    Yes i would fit, but would sound muffled
  11. prscht
    prscht Junior Member
    37
    Parsippany, NJ
    KK6PD,
    Neat Bass800 install. did you run your high level speaker input from a rear door speaker? What other options are there to supply input to the subwoofer in a Prius with standard 6 speaker system (non-JBL)? Thanks.
  12. KK6PD
    4,003
    944
    118
    Hi there, no I came right off the plug at the JBL amplifiers output!
    Best option is as I did, come off the plug on the amp, for non JBL users, the output cables are at the back of the HU, anybody, thoughts on this location..?.!
  13. supra90
    supra90 New Member
    30
    florida
    2001 Prius
  14. KK6PD
    4,003
    944
    118
    That's one of the nice features of the BOSS, it accepts both Hi Level (Spkr) and Lo Level (Line Out) as inputs!!!
  15. Grayson73
    Grayson73 Junior Member
    62
    Maryland
    Is the Boss BASS600 better or the Kenwood KSC-SW10?
    I'd like it to be hidden and not take up space, so that leaves under the seat or in the compartment above the spare, right?
  16. KK6PD
    4,003
    944
    118
    Pretty much!!!
  17. CocoaBeachPriusChick
    Cocoa beach Florida
    I installed Rockford Fosgate P2s, and amp and capacitor to my 2008 with JBLs (I loved the jbls before the upgrade) Since the install I feel that the sound is lacking, I have to keep the volume in the 20s to not overpower the subs? But when I turn them down to raise the volume I lose tons of bass no matter what level the volume is. Is there a solution for this? I need help lol
