Basic research: mechanical energy storage
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by bwilson4web, Sep 22, 2009.
  1. bwilson4web
    15,518
    There is a long road from theory to practice (aka., nuclear fusion power plants, nuclear energy) so one needs to take such announcements with a bit of skepticism. Still, this is interesting:
    Green Car Congress: MIT Researchers Find That Elastic Energy Storage Systems Built With Carbon Nanotubes Could Match Li-ion Battery Energy Densities
    Nanotubes have amazing properties ... something like "unobtanium" ... but they are devilishly difficult to make in useful forms. Still, it is an interesting material even if still more microscopic than usable for real world structures.
  2. a64pilot
    a64pilot Active Member
    771
    62
    Albany Ga.
    A wind up Prius:D:D Put a big wind up key on top? Ever seen an inertia starter like on an old Stearman?
  3. wfolta
    wfolta Active Member
    366
    146
    Washington DC
    2018 Prius
    Actually, and more interestingly, I just read about using specially-modified bacteria and nanotubes to create highly efficient batteries that don't use toxic ingredients.
    The spring idea seems like it's a LONG ways off. Sort of like someone saying in ancient Rome, "Hey, we can make swords out of metal, so with just a little more research, it shouldn't be a big deal to make boats and enormous buildings out of metal, too."
  4. SageBrush
    SageBrush Senior Member
    11,627
    2,530
    Southwest Colorado
    I'm imagining a PSD and smart spring at the base of a windmill. Cool
    If society does not implode in the next couple of centuries, I think this age of burning fossil fuels for energy, and using massive amounts of metals for mechanical applications will be known as the 'age of waste'.
  5. Rybold
    Rybold globally warmed member
    2,760
    322
    Southern California
    I fully support the research for any new technologies. I'm open minded. If this works, excellent! I just hope that unlike traditional rubber that dries up and cracks after several years, these carbon nanotubes last the life of the vehicle, and do not have to be replaced regularly; creating an environmental waste impact.
  6. DavidA
    2,328
    1,812
    Chicago western burbs
    It'll happen when carbon nanotubes and buckyballs are used to build the tethers for a space elevator. The astronauts can be the early adopters. Until then, I'll just use wind-up rubberbands like I've always done. Whatever happened to flywheel energy storage?
  7. bwilson4web
    15,518
    The latest I'd read last winter were plans to use them in formula 1 racing.
  8. drees
    drees Senior Member
    1,782
    247
    IIRC, everyone ended up using battery KERS systems. And only a few cars used them because of the limitations they put on the system.
  9. Glider
    Glider New Member
    135
    30
    Memphis
    When I firs saw this, two things jumped into my mind.
    1) stored energy/weight is high, but that is largely because the weight of carbon is so low, not necessarily that the stored energy is so high. This thing has to take you 200 miles and up hills, or we going to stop and wind it up with a hand crank every 10 miles </grins>... sorry....
    2) what about stored energy/volume? If there is a lot of wasted space in this gizmo, a car for two people will look like an 18-wheeler. </more grins>
    And of course, you actually have to make a big version work.
    Well, it sounds like a lot of fun in the lab anyway. The race is on between carbon nanotubes, flywheels, compressed air, zap caps, cold fusion.... and... I almost forgot... batteries.
  10. bwilson4web
    15,518
    So then I was thinking, "nanotube cords in tires." If they are efficient at returning energy with low loss, perhaps a nanotube cord and nanotube rubber complex might reduce tire flex losses ... but there in lies the path to madness (aka., nuclear power advocates hanging out in airports.)
    So I'm sitting at a bar typing the note and wondering how great would be a nanotube cocktail straw? ...
    Basic research, always and the more the merrier. But there is such a long, long lead time from the lab to practical products ... unless it can be used in a weapon.
  11. Rybold
    2,760
    322
    Southern California
    In F1 racing, drivers accelerate within a second after braking; however, on the street people may drive miles between starting and stopping ... errr, uh, stopping and starting :D Okay, you win. :)
    But like Glider said...flywheels are HEAVY! Rubber bands weigh much less (maybe; it depends on the size and weight of the belt that would drive a CAR) ....But then again, flywheels may weigh less than batteries.
    Very true.
