Batteries are leaking
Discussion in 'Gen 2 Prius Main Forum' started by 299K, Jan 21, 2020.
  1. 299K
    299K Junior Member
    30
    Cleveland, OH
    My traction battery has started leaking. Thoughts?
  2. SFO
    SFO Senior Member
    5,302
    4,250
    Northern California
    Fix it before it leaves you stranded?
    fotomoto likes this.
  3. edthefox5
    edthefox5 Senior Member
    10,096
    4,834
    Clearwater, Florida
    It will soon throw a red triangle of death on the dash and go into limp mode. It will throw a ground fault nag.
    One or more battery modules have cracked leaking electrolyte.
    New battery time.
    52,408
    be careful of your skin
  5. PriusCamper
    PriusCamper Senior Member
    13,088
    5,308
    Pacific Northwest, USA
    It's possible it's just one of 28 modules that leaks and can easily be replaced with one of similar age and health... These are often caused by too much heat. Perhaps your hybrid battery cooling fan needs cleaning? First step is to pull that pack out and clean everything, replace corroded nuts and bus bars and voltage sensors and find out ho many modules are leaking.
  6. Priuslover09
    Priuslover09 Member
    365
    48
    Dc
    Is it a big or small leak in the battery ?
  7. SFO
    SFO Senior Member
    5,302
    4,250
    Northern California
    How would one determine if it was big or small?
    Would it be by the number of modules, or by the number of DTCs, or something else?
    Raytheeagle likes this.
  8. 299K
    299K Junior Member
    30
    Cleveland, OH
    A couple modules are leaking where stud enters the cell. Just spread around some baking soda, no codes or triangle yet.
    George W likes this.
  9. PriusCamper
    13,088
    5,308
    While that's the most common place to notice the leak, it doesn't mean that it's the exact location. If I were you I'd pull the pack and deep clean everything, replace bus bars, voltage sensor harness and nuts so you'll have an easier time detecting the location of the leak.
    Because there's no ground fault error code, if you're lucky the leak was NOT from a crack in the base of the module where the stud enters but instead from where the bus bars connect which could of been caused by a single over-heating event and if you keep don't have anymore overheating events you'll be good for a while.
    Check you hybrid battery cooling fan, when that gets clogged that's when things heat up. You'll be in the clear if there's no more signs of leaking this coming Summer.
    Data Daedalus likes this.
  10. Tim Jones
    Tim Jones Senior Member
    1,759
    565
    SE Texas
    2011 Nissan LEAF
    Get a new one.....
  11. PriusCamper
    13,088
    5,308
    wasteful & irresponsible...
  12. Tim Jones
    1,759
    565
    SE Texas
    2011 Nissan LEAF
    That's kinda harsh... I've played the battery game. I drive my prius long distances.
    I need daily reliability especially when hundreds or thousands of miles from home often.
  13. PriusCamper
    13,088
    5,308
    One person false sense of reliability, is another person's sense of throwing the baby out with the bath water... And with 2/3 of US citizens having less than a $1K in emergency savings, rebuilding a pack is often the only option they can afford.
  14. Tim Jones
    1,759
    565
    SE Texas
    2011 Nissan LEAF
    You win..... : )
    Been through this before.
  15. 299K
    299K Junior Member
    30
    Cleveland, OH
    The leak appears to be at the terminals where the buss bars are bolted.
    SFO likes this.
  16. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,093
    Columbia, SC
    If you just have some greenish looking fluid on the sides of the modules, just clean it up a bit and roll on. It'll let you know if it ever really needs work done on it. A HV isolation fault will not leave you stranded, as it will let you continue to drive even after triggered (until you turn the car off). Once you turn the car off, it won't let you go ready again unless you reset the code (disconnect the battery)
    PriusCamper likes this.
  17. PriusCamper
    13,088
    5,308
    Yes, what he said... The leak most likely was a one time event when things were hot... If the leak was coming from below it would likely be something that you'd need to address. So you lucked out for now!
  18. 299K
    299K Junior Member
    30
    Cleveland, OH
    Thanks!
    I carry a paperclip and an obd reader/eraser along with a 10mm wrench wherever I go. I did rememove the bussbars and soak them in vinegar, then reinstalled. No problems so far.
