Battery air filter fastener issue
Discussion in 'Gen 4 Prius Technical Discussion' started by Wraiththe, Feb 27, 2024.
  1. Wraiththe
    Wraiththe Member
    258
    49
    Charlotte NC
    On the passenger side of the back seat base, there is an air filter for the battery. The panel has a fastener with a philips screwdriver head. Supposedly you can turn it to get it to come out, then pull out the fastener. When I turn mine, nothing happens other than spinning. Yes, I hold down the outside ring so that does not spin with it. Is there another way to do it without damaging the fastener?
  2. Wraiththe
    Wraiththe Member
    258
    49
    Charlotte NC
    After searching FOR EVER and talking on the phone with Toyota FOR EVER... seems like the part number is 90467-06165-C0.
    It is supposed to turn out, but is is not coming out and I do not wish to force it, for risk of damaging the filter cover.
    I am going to try and scope the air intake... just to be sure it is clean deep inside. Ruling out heat affecting Gas Mileage. These days I am lucky to get 47.6 Mpg. Sometimes it goes down to 37... and that is just not right.
  3. AzWxGuy
    AzWxGuy Weather Guy
    982
    496
    Tucson, AZ
    2021 Prius
    The trick is to apply just enough tension to engage the Philips bit then apply negative pressure (pull) while slowly turning. It should just pop out. Make sure you use a relatively new Philips bit with nice, sharp edges.
    Wraiththe likes this.
  4. Wraiththe
    Wraiththe Member
    258
    49
    Charlotte NC
    I did... Just bought a new one in case... will try again.
  5. Mendel Leisk
    38,751
    Japanese Industrial Standard (JIS) screwdriver tips are similar to Phillips, but have less rounding at tips, maybe better suited for finessing those out. They come in comparible sizes 1 through 3, and 2 is likely what’s needed.
  6. Doug McC
    Doug McC Senior Member
    1,006
    377
    Midwest
    2022 Prius
    Simple solution: using some flat surface item (flat head screwdriver, plastic trim tool, etc) slid behind the outside ring and prying on it (gently), while unscrewing the plastic screw. Basically, you are doing what you were trying to do by holding the outside ring, but adding tension to it at the same time.
  7. vvillovv
    vvillovv Senior Member
    3,689
    1,302
    NY
    The Car Care Nut youtube channel hosted by AMD did a video on cleaning the traction battery inlet air filter, but I think he used a Prime when making the video which doesn't have the screw mentioned in your OP. The way to do it for the Prime is to pull the door rubber seal off the door seam for a few inches above and below the filter plastic. Be that as it may, if it helps you find a notch to insert a small screwdiver or any other way to pull the filters plastic grille away from the opening, that would be a win win.
    Those plastic screw pins are a real pain when the don't back out like they're supposed to.
    Sometimes a plastic trim tool that looks a little like a small claw of a claw hammer can sneak under the screw heat and pull it out pretty much like the other none screw type plastic pins that are everywhere all around the car.
    Doug McC likes this.
  8. Wraiththe
    Wraiththe Member
    258
    49
    Charlotte NC
    So this worked. I found a bit that fit snuggly, then just using the bit, turned it with no forward pressure. Slowly is caught and started to come out. Now I have two of them. (bought one in case I had to destroy it.
    Well, I cannot get the scope behind the fan cage. May have to remove stuff to go in further. Hoping someone has finally come out with a video on how to get a good look inside.
