Battery and Battery Fan Cleaning
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by 94hawk213, Jul 1, 2016.
  1. 94hawk213
    94hawk213 Junior Member
    33
    My MPG has decreased from about low- to mid-40s to mid 30s, so I'm going to try a few things to remedy that. For one, I'm going to clean the battery and battery fan. I have about 122,000 miles and a sweet little puppy who travels with me a fair amount, so it seems like a reasonable step. However, I can't find a good write-up with pictures. Could someone recommend one? Thank you!
    #1 94hawk213, Jul 1, 2016
  2. S Keith
    S Keith Senior Member
    799
    329
    AZ
    2003 Prius
    ...way to end a post? :)
    The fan isn't your problem. It might be a contributor, but you need to run the discharge test in my signature. You're battery is likely to fail soon.
    Good luck,
    Steve
    #2 S Keith, Jul 1, 2016
  3. 94hawk213
    33
    Yeah, the Internets was having trouble last night. Anyway, that's not good to hear. I'll try the discharge test you mentioned. How much are the batteries going for now? :(
  4. S Keith
    799
    329
    AZ
    2003 Prius
    I've read $2800-3600 dealer install. In the Phoenix area, it's about $3000-3200. As of 1/2016, Toyota increased the warranty on the battery to 3 years for non-commercial use.
    What part of the USA?
  5. bisco
    52,368
    check some of the mileage threads, a number of engine problems can reduce mpg's, such as a dirty throttle body and maf sensor. have you done the standard 120k maintenance? fluids, plugs?
    94hawk213 likes this.
  6. 94hawk213
    33
    S Keith, I'm in Dallas, Texas. My car is a 2008 with 122,000 miles. Unfortunately, I won't get the 150,000 miles that California and other states have.
    Bisco, I previously cleaned the MAF sensor and restored about 3-4 mpg. I'll try it again, but I suspect that that's not the issue. I did the plugs, but haven't done the fluids yet. I just changed my Michelin Energy Saver tires for Michelin Defender tires, and that accounts for about 1-3 mpg loss, but the rest of the mpg loss is so far unexplainable.
  7. S Keith
    799
    329
    AZ
    2003 Prius
    The discharge test will give you an idea of the state of your battery.
    If you're a DIY guy, a hybrid automotive prolong grid charger system may extend the life of your existing battery.
    If you decide you need a replacement, you can't go wrong with Texas Prius Battery Replacement. Matt is a sharp guy, and he produces a quality product.
    strawbrad and 94hawk213 like this.
  8. fotomoto
    fotomoto Senior Member
    5,639
    3,815
    So. Texas
    Dollars to donuts I'd bet you're losing battery performance as you're getting to that point in time, use, and environmental conditions (Dallas heat). If new battery costs are prohibitive to you, I would suggest researching the use of a grid charger/discharger and using it BEFORE you lose a battery cell module. Once the car begins throwing codes, it's usually too late and only replacing the failed module(s) or entire battery is the remedy. And YES clean your fan especially if you frequently carry pets.
  9. 94hawk213
    33
    Thanks, Doug. Does anyone have a link to good directions with pictures for the fan and battery cleaning? I'd like to try that first. Thanks!
  10. Mendel Leisk
    41,879
    If it's at all sim to 3rd gen, it's not that difficult, just winging it. Have on hand a socket set, a few pliers and screwdrivers, and a trim pry tool.
    Then just follow the ductwork, there should be a logical and reasonably apparent removal course. Keep all the fasteners organized. I found with our 3rd gen there were a boatload of tenacious fasteners, most of which I omitted at install, with no ill effects.
    It shouldn't be necessary to completely remove the fan to clean it; don't do any more than necessary.
  11. bisco
    52,368
    you can find it on you tube. i think luscious garage did one.
  12. 94hawk213
    33
    Thanks S Keith and everyone. I'll do the test and report back. If the battery is dying, then I'll probably check out Texas Prius Battery Replacement, though it looks like they're out of refurbished batteries right now.
  13. jeff652
    jeff652 Senior Member
    607
    624
    Idaho
  14. 94hawk213
    33
    Sweet. Thanks, Jeff!
