Battery and Computer Replacement
Discussion in 'Gen 2 Prius Main Forum' started by priusindanapoint, Feb 11, 2008.
  1. priusindanapoint
    priusindanapoint Prius Because
    Dana Point, CA
    :eek:
    I have a 2007 Prius with 19,000 miles. I went to start the car yesterday afternoon and the dashboard lit up like a nuclear power plant control panel. Among the lights was the "famous" red exclamation mark. I also heard the fan noise coming from the rear side seat, which I understand is the battery fan. I called our local dealer (San Juan Capistrano Toyota) and they told me to drive the car in and they would diagnose. I drove the car and left with the dealer. I just received a call to notify me that my car needs a new main battery and a new computer.
    Has anyone else had anything like this happen with a relatively new Prius or is there anything I need to be aware of?
    Thanks for any and all feedback.
  2. efusco
    efusco Moderator Emeritus
    19,891
    1,194
    Nixa, MO
    Pretty odd, not unheard of, but darn odd. Find out whatever you can as far as the exact codes they pulled and such. Sometimes they'll get one code and just pull the possible bad parts all at once rather than muck around trying to get an exact diagnosis.
  3. richard schumacher
    7,664
    1,043
    United States
    Any chance that you had been driving with the battery vent intake (the grille to the right of the rear seat) covered or blocked? Doing so would overheat the battery system, and enough of that would damage it.
  4. patrickindallas
    patrickindallas Shire rat
    676
    36
    Vancouver, WA
    I'm surprised they told you to 'drive it in'.
    Would they have been on the hook for towing charges or something?
    My manual sounds like a broken record with the number of times it states "Turn off car, and have it towed to dealer."
  5. KTPhil
    KTPhil Active Member
    1,379
    At least it is covered under warranty. But please do get as much info as possible, since this an example of an extremely rare event--HV battery replacement.
  6. jjf
    jjf New Member
    Madison, WI
  7. Tempus
    Tempus Senior Member
    1,690
    Washington DC
    My experience was similar. They also told me to drive it in. I just had the battery replaced too though.
    I posted about it somewhere but it's back in my history.
  8. Qlara
    Qlara New Member
    488
    I guess the dealer has no clue of what went wrong (or no skill to fix the Hybrid), and simply replace the 'obvious' culprits under warranty.
    This is very much like in computer ownership: Having some errors pop-up in Windows Vista, and the Support guy just ask you to put in the Windows Recovery Disc to rebuilt the OS from scratch instead. It's the best way to fix problems when they don't know how to troubleshoot it.
  9. galaxee
    galaxee mostly benevolent
    9,810
    468
    MD
    um. the warranty wouldn't pay for such a repair without either a set of diag codes that indicate the mentioned parts failures, and/or lots of time on the phone with tech support.
    believe it or not, sometimes these things fail. it sucks, but that's why we've got a warranty. it's the shots in the dark on the customer dollar we should be worried about. those do happen.
  10. priusindanapoint
    Dana Point, CA
    I just received the car back from the dealer with a new battery and computer - I will post error codes found and exact replacement parts tomorrow when I get back into town -
  11. Doc Willie
    1,717
    144
    Out there, somewhere
    Can we have picture of the new battery? ;)
  12. clintd555
    clintd555 New Member
    251
    How has the new computer and battery effected your MPGs so far?
  13. Rangerdavid
    Rangerdavid Senior Member
    1,362
    52
    Boone, North Carolina
    Three Touring
    i hope your troubles will soon be over, but in the meanwhile, keep track of their attempts to fix the problem, as well as how many days your car is actually in the shop. Never know when you might have a lemon law claim. :cool:
  14. priusindanapoint
    Dana Point, CA
    OK -
    The car was in the shop for two days. The repair invoice states the following;
    Cause 99
    190991 CODES P3000 P3013 C1259 C1310 - FAILED
    BATTERY - REPLACE BATTERY AND ECU
    7092 W
    1 G9510 - 47031 BATTERY ASSY, HV SUP
    1 89890 - 47090 COMPUTER ASSY, BATTE
    ALL DONE FOR NO CHARGE - - I WILL BEGIN TO DRIVE TOMORROW AND LET YOU KNOW HOW THINGS GO
    tHANKS:eek:
  15. priusindanapoint
    Dana Point, CA
    Drove the car - seems to ride like new - averaged 48.6 mpg in my first 100 miles.
    Can anyone tell me what the codes mean that were posted in my earlier post?
    Thanks
  16. alanh
    alanh Active Member
    1,175
    99
    Phoenix, AZ
    P3000 = Battery Control System malfunction
    P3013 = Battery Block 3 becomes weak
    C1259 = HV Regenerative System malfunction
    C1310 = Malfunction in HV system
  17. richard schumacher
    7,664
    1,043
    United States
    Probably a simple case of infant mortality. It's annoying, but no reason to worry about other things.
