Battery ballancing if there is no error code
Discussion in 'Gen 2 Prius Technical Discussion' started by cosminman, May 12, 2017.
  1. cosminman
    cosminman Junior Member
    26
    Romania, Europe
    Hello,
    As many of you have probably read, I had a problem with the ICE because of a rag that got sucked in the air duct before the filter enclosure. ( https://priuschat.com/index.php?threads/179082/ )
    With this occasion, I took out the HV battery because I assumed it was an error generated by the failure of a cell and not because of the lack of air at the engine. I cleaned the buss bars and checked the voltages, everything was ok.
    Since my battery is over 10 years old, I am considering now to get it out again and ballance charge all the modules, as preventive maintenance and to regain capacity. It is clearly weaker now,because of its age. Am I exaggerating, or it would be beneficial? Doing this on a yearly basis should be good for the battery, or I would do better to just let it be?
    I am planning to get 4 rc chargers from turnigy and do that. As far as the discharge is concearned, i think I will use 2 55w bulbs to discharge the modules to 6v each, and then start the charge, the second diacharge to 5.5v and recharge and finally discharge to 4.8v and do the final charge. The final discjarge-charge cycle will be done solely by the rc charhers,because I want to see how much milliamps hour I can take out from the modules.
    Do you think my approach is correct?
  2. srellim234
    srellim234 Senior Member
    1,198
    1,687
    Laughlin, Nevada
    I'm not knowledgeable enough to address the technical aspects but I do have an opinion related to your approach to the balancing issue.
    I think for the convenience you might be better off spending a little extra now and going with a charger/discharger that won't require you to dismantle the battery every time you want to balance it. I'm in the process of getting the Prolong charger/discharge system (ordered this week, I'm awaiting delivery and plan to install the harness and balance in June). I'm not a huge DIY person and like that I can leave the harness in place. Then I can maintain the battery cells all at once without tearing the car apart every time.
  3. cosminman
    26
    Romania, Europe
    I agree. But for the moment, the cost of the prolong charger is off-budget (I a, from Eastern Europe and frankly I can not afford it, to ale the explanation short). This is why I am thinking g to get some D.C. Charger for arround 120 USD
    iPad ?
    Raytheeagle and srellim234 like this.
  4. srellim234
    1,198
    1,687
    Laughlin, Nevada
    I totally understand. Good luck with your task. I'm sure someone with a lot more knowledge than myself will help you out here.
  5. WilDavis
    WilDavis Senior Member
    2,492
    2,153
    49
    ...sorry I'm late arriving at your party, but here's my 2¢, read all you can about grid-charging, and the basic theory behind it. Hybrid Automotive's Prolong System is a good place to start. Jeff Sloane (Hybrid Automotive) is very helpful, and there's all manner of useful information to be had by using the search function here on PriusChat! Just remember that slow and controlled (both charging and discharging) is part of the secret! Good luck! (...and welcome to PriusChat!) - hope this helps
    cosminman likes this.
  6. ericbecky
    ericbecky Hybrid Battery Hero
    4,371
    3,220
    Madison, Wisconsin
    If you have done it before and are comfortable doing it again, I say go for it.
    Yearly is probably good for an older battery pack.
    I personally don't see much reason to go below 6v, but it's totally up to you if you want to go lower.
    SFO likes this.
  7. SFO
    SFO Senior Member
    5,297
    4,235
    Northern California
    Would be very interested in other opinions on this topic and or comment.
    When is it OK to discharge a pack below .8 or .5 volts?
    When is it NOT OK to discharge a pack below .8 or .5 volts?
    Some think that taking a healthy pack below certain voltages may not be in the HV packs best interest.
    What is considered a healthy pack?
  8. RobH
    RobH Senior Member
    2,369
    979
    70
    Sunnyvale, California
    Even if you don't purchase a charger/discharger from Hybrid Automotive, I'd recommend reading the manuals for their devices. Their discharge procedure uses a stepped load, initially about 1.5 amp, going down to about 0.2 amp as the voltage goes down. The lowest voltage they reach with the fancy discharger is 17 volts for the full pack, which is 0.6 volts per module. I have to assume that the reason they go so low is that it is necessary for the best result. Note that they operate the cooling fan during the charge/discharge.
    jerrymildred and Raytheeagle like this.
  9. cosminman
    26
    Romania, Europe
    So... I ordered 4 Turnigy Accucell chargers and put them to work. I changed the charging cables using 4sq mm copper cable, the original ones were pretty thin and I was afraid of power losses. They are fed by a 33 amp 12v power supply and everything is powered up through a UPS, in case of power grid problems. The charging cables are connected to the bloks with the bussbar nuts. Wish me luck, will post here the results.
    I remember everyone, my battery is not throwig any codes, I do this as preventive maintenance.
    I put the whole assembly in the coolest part of the house, where the temperature is pretty much constant.
    Trimis de pe al meu LG-D858HK folosind Tapatalk
    SFO likes this.
  10. cosminman
    26
    Romania, Europe
    SFO likes this.
  11. MTL_hihy
    MTL_hihy Active Member
    536
    261
    Maritimes, Canada
    The HA system is really the best way IMHO but I have done both and was successful using the RC charger method as well. My suggestion is to use low current when charging and the highest settings possible when discharging. The idea here is to keep the modules as cool as possible (heat builds on the charging side) so if you keep the current low enough you are effectively grid charging but at the module level. Read the HA documentation as suggested above and it should be clear what the steps are that you are trying to replicate. Don't go below 6V per module unless you also use low current in the discharge process to prevent cell inversion. Hope this makes sense.
  12. cosminman
    26
    Romania, Europe
    Yes it makes sense, thank you. I charge 2Amps and discharge at arrou d 1.4-1.5. The cutoff linit was at 7000 mah, and it reached it everytime saying ”over charger capacity”. Now I am trying with 7300 mah cutoff and if that does not reach the delta peak i`ll go 7500. Delta peak is set at 7mv/cell
  13. MTL_hihy
    536
    261
    Maritimes, Canada
    Keep in mind even the 2A is alot compared to what grid charging does........below are the specs on the Prius Prolong grid charger
    Technical specifications (94-09 Prius):
    Input Voltage: 88 ~ 264VAC
    Input Frequency: 47 ~ 63Hz
    Input Leakage: <2mA / 240VAC
    Output Voltage: 0 - 250V
    Output Current: 350mA CC
    Max rated ambient temperature: 100 degrees Fahrenheit (38 degrees Celsius)
    This is also over an entire battery pack so the reason why we need to use cutoffs on RC chargers is because the current at 1-2A is still high enough to generate enough heat to cause damage to the module once it reaches the fully charged state. It's hard to get to a fully charged state without the possibility of overcharging which is why the HA method tends to produce the best results. On the discharge side you want the highest current possible simply to save time when cycling, they can see huge amps in use but again the ECU never lets the battery out of the 40-80% SOC range.
    Once you are done with the RC chargers (checking capacity) make sure to load test them all with a headlight as well.
    Prolong® Battery Module Load Tester User Guide &ndash; Hybrid Automotive
    #13 MTL_hihy, May 18, 2017
    jeff652 likes this.
  14. RobH
    RobH Senior Member
    2,369
    979
    70
    Note also that the Prolong grid charger operates the cooling fan, even with 0.350 A charging.
  15. cosminman
    26
    Romania, Europe
    I know the Prolong grid charger would be my best option, but I can not afford one right now.
    I started cycling the modules, first discharge was between 2200-3000 mah. The second one went up to 3800-4000 mah. They seem to regain capacity quite well. I will see the 3rd one.
    I did check the voltage drop by using a 110 w load for 120 seconds, here are the results:
    #. Initial V load V V drop
    1 7,75 7,32 0,43
    2 7,75 7,32 0,43
    3 7,75 7,31 0,44
    4 7,74 7,31 0,43
    5 7,74 7,32 0,42
    6 7,74 7,32 0,42
    7 7,74 7,29 0,45
    8 7,74 7,3 0,44
    9 7,74 7,28 0,46
    10 7,74 7,31 0,43
    11 7,74 7,29 0,45
    12 7,74 7,31 0,43
    13 7,74 7,31 0,43
    14 7,74 7,28 0,46
    15 7,74 7,32 0,42
    16 7,73 7,3 0,43
    17 7,74 7,3 0,44
    18 7,73 7,29 0,44
    19 7,73 7,3 0,43
    20 7,74 7,29 0,45
    21 7,74 7,3 0,44
    22 7,74 7,31. 0,43
    23 7,74 7,32 0,42
    24 7,74 7,32 0,42
    25 7,74 7,32 0,42
    26 7,75 7,33 0,42
    27 7,75 7,34 0,41
    28 7,75 7,32 0,43
    Seem hey are pretty healthy.
    iPad ?
    MTL_hihy likes this.
  16. cosminman
    26
    Romania, Europe
    Added some extra cooling:) 1495193906492.jpeg
  17. MTL_hihy
    536
    261
    Maritimes, Canada
    Load testing looks pretty good, keep cycling them but use 1A charging to help protect the modules from heat damage.
  18. cosminman
    26
    Romania, Europe
    One of them swallowed a little at peak charge, but it returned to normal state in a few hours. Did I ruin it? Or this is a sign it reached full charge ? There is a fan blowing over the pack,for best heat disipation.
  19. MTL_hihy
    536
    261
    Maritimes, Canada
    That is the result of overcharging at too high an amperage (ie you reached full SOC) and continued to try and charge the module (thereby causing it to swell). It should be ok but this is why I suggested to use lower charge currents when doing this (at the expense of time of course).
  20. R-P
    R-P Active Member
    804
    288
    Netherlands
    I bought a few iMax B6 chargers (similar to your Turnigy) to do the same: preventative maintenance on my battery pack.
    I started with bicycle NiCd (5Ah) and NiMH (10Ah) cells to get some feel for it and am glad I did.
    I have an iMax 50W (charges at a maximum of 50W or 5A, whichever is the limiting factor) and two newer 80W ones (charges at 80W or 6A, whichever is the limiting factor).
    The 50W version has no trouble sensing the delta V (on Auto, iirc it is set to 7mV/cell). The 80W versions never stop and always run into the capacity limit (even when set at twice the Ah rating of the cells, regardless if using Auto or 5mV/cell)
    After doing research, I found information that a delta V can be hard to detect when the charging current is too low*. Advice was to use 0.5 to 1C to make sure it would be enough to sense the delta V.
    Can someone confirm this charge-current vs delta V vs capacity relation?
    I had hoped to use the 80W chargers as they can also discharge up to 10W, so I could simply cycle one Prius module per 80W charger and come back after 3 days with a nice list of discharge capacity and energy fed into the module for e.g. 4 charging cycles.
    For now, the conclusion is that the 80W versions are worthless unless I can use them with a temperature sensor and skip the delta V meaasurement. So for now the project is shelved and I am following this thread with interest.
    * the 50W versions charges the 10Ah cells with 2.5A and stops at rated capacity (+10% or so) as expected. The 80W version never stops, regardless if using 2.5 or 6A charging current on the same cells. I tried this on 10 cells (12V) and tried the 6A charging on 5 cells (as with 10 cells you would run into the 80W charging limit and not quite reach 6A).
    #20 R-P, May 29, 2017
