Battery bank question
Discussion in 'Newbie Forum' started by tnDave, Jun 5, 2020.
  1. tnDave
    tnDave New Member
    Crossville TN
    I
    Wondering if this is good for a 12vdc solar application, they are 45ah so in series I would get over 200ah's in series and that doesn't seem alot for me. Am I missing something? TIA. 85181631_236818917495387_8631351897938198528_o.jpg
  2. vvillovv
    vvillovv Senior Member
    4,332
    1,516
    NY
    is tnDave still with us? probably not but anyways .....
    Probably OK - IF
    how do you plan to use the charge from this storage?
    lightly I would assume as the batteries are not deep cycle lead acid.
  3. ChapmanF
    18,567
    Careful here. Combining batteries, you get to add voltage or add amp-hours, but not both. In series the volts add. You would have 60 volts there ... at 45 amp-hours.
    There's another place the same issue comes up, where in that case it seems the marketers are making the mistake deliberately.
  4. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    Yes. Right.
    You do NOT want to connect them in series.....for any "normal" use.
    For additional capacity, they would be connected in parallel......but that isn't a really good idea either.
    (How did we ALL miss this the first time around ?)
