Battery Bar Colors
Discussion in 'Gen 2 Prius Main Forum' started by ladyinblack, Aug 1, 2006.
  1. ladyinblack
    ladyinblack New Member
    I got my Prius :p alittle over a week ago, while driving around just for fun on Sunday I noticed the colors on the display go from blue, to pink, and sometimes even yellow. I looked in the manual and god forbid if it mentioned anything about the color changes. Is this normal and what does it mean? :huh:
  2. efusco
    efusco Moderator Emeritus
    19,891
    1,192
    Nixa, MO
    <div class='quotetop'>QUOTE(ladyinblack @ Aug 1 2006, 10:47 PM) [snapback]296071[/snapback]</div>
    I highly recommend you go to john1701a.com and look at his various guides and such. Lots of great info that explains little things like this there.
    In the mean time, I've never seen the battery turn yellow...green, yes, but not yellow. Perhaps there's something different on the '06.
    The bars turn pink when the SOC (state of charge) drops to 2 bars or less (actual SOC is about 40-50% in that range), It's blue in the mid range (50-60%), and turns green when it gets to a high SOC--above 60% or so. Nothing you need to do or worry about, just flashy and colorful so you know what's going on.
  3. ladyinblack
    Thanks Doc always appreciate your immediate responses you've been very helpful :)
  4. jmccord
    jmccord New Member
    199
    San Diego, CA, Earth
    My 2006 display shows green, blue, and a shade of purple / "pink" that is hard to describe.
    We could probably devote an entire PC thread just to naming that low battery color :p
    On second thought, I should do a search, as its probably already been done!
  5. sl7vk
    sl7vk Member
    518
    23
    Salt Lake City
    I would call it Magenta. :D
