Battery Block 2 Low replaced but issue persists?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Miguel Olivares, Jul 14, 2023.
  1. Miguel Olivares
    Miguel Olivares Junior Member
    56
    Oakland
    hey all
    on a second hehe prius, the christmas lights came up and far went into limp mode
    upon using techstream, my dad and i identified battery block 2 to be low voltage.
    upon balancing and replacing the cell, it still is giving the same issue.
    the car will run for about 50 miles before the lights come on and the HV fan turns on full blast
    what else do y’all think could be happening?
  2. JC91006
    16,476
    8,393
    if you're having the same issue with block #2, it just means you didn't replace the correct module(s) or the replacements are just as bad
  3. Brian1954
    Brian1954 Active Member
    797
    299
    South Central PA, USA
    Did you replace one of the modules in block #2, or did you replace both modules in block #2?
    #3 Brian1954, Jul 15, 2023
  4. Tombukt2
    Tombukt2 Senior Member
    8,920
    1,553
    Durham NC
    While in there how did all the bus bars the bottom of the battery tray You can look with a flashlight All that look any leakage seepage ever happen in there bus bars and nuts frosted and corroded that needs to be dealt with All of those things will cause the same nonsense not just a low battery block. All of those things can fubar you're system and lite you up.
