Battery capacity decrease
Discussion in 'Prime Technical Discussion' started by bowang, Jan 28, 2017.
  1. bowang
    bowang Member
    45
    37
    Anyone also notice battery capacity decrease? And how was battery capacity measured? I calculate from 2 numbers shown on dashboard
    26.4(mile range)/3.8(mile per kWh)=6.9(kWh usable battery capacity)
    A month ago I was able to get 7kWh weather was 10F colder at 60F.
    Assume 24% battery capacity loss in 4 year, that's ~1% loss every 2 month. Which is still not too bad.
  2. priuscatprimeguy
    priuscatprimeguy Senior Member
    2,730
    2,640
    Farmington Hills, Michigan
    EV range is calculated by your average speed over time, the faster you go the lower your average EV will be over time.
    49,490
    you will get some degradation, especially in the first year. expect 10-15% over 5 years, and just a bit per year after that.
  4. Trollbait
    11,560
    With a PHEV, the degradation can all be covered by the buffer in the battery. So you might not seen anything on your end.
  5. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    I think you are measuring the computers more correctly reporting your driving style.
    At first they use ideal ranges, but they learn your actual range over time.
  6. CaliforniaPrius
    CaliforniaPrius Active Member
    313
    201
    Alameda, California
    Wow, so 0.5 kwh per month. By this assumption, you won't have a prius in 6.9/0.5=15 months. Less than 1.5 years. My condolences.
  7. giora
    giora Senior Member
    1,966
    730
    Herzliya, Israel. Car: Euro version GLI
    2013 Prius Plug-in
    It's really too early to make any statement. You need much more time/miles to notice any degradation. Don't worry now and enjoy.
    Just the way the numbers are displayed (truncating to first decimal place) can lead to opposite results of 6.9 kWh last month and 7 kWh now.
    Example: 26.4 miles could be anything from 26.40 to 26.49! then 26.49/3.8=6.97 kWh.
    If you really want to monitor your battery degradation in time and use, the best accurate way to do it is to install kWh meter (counter) on the line feeding the car.
    If you do that, take measurements of kWh (consumed from wall) per full charge now:
    1. At various ambient temperatures.
    2. From same starting point (say, always from 0.1-0.2 EV miles remaining or 0.6-0.7 remaining or whatever).
    Repeat these measurements a year from now and compare.
    #7 giora, Jan 29, 2017
