  1. gypsiqueen
    gypsiqueen New Member
    Yesterday
    Colorado
    I hope this question is OK. I inherited a 2014 Prius 3 from my dad. He only drove it 4,000 miles, and had the electric battery hooked up to a charger when it was sitting (years). It has just over half a capacity when doing normal driving. My question is, when we were driving through stop and go traffic on the mountain pass last week, the battery dropped to 2 bars. Is this normal? I completely freaked out because I don't want it to die in the middle of a mountain pass. Will it charge itself when it gets that low? We're looking at 2 hours of stop and go traffic on the way back home over the other side of the pass. Is it ok if it sits that low for hours? Or should I have a new battery put in? Please no super technical answers though, I'm still working on reading the manual, but I need to know since we're driving it soon.
  2. OptimusPriustus
    OptimusPriustus Active Member
    313
    131
    Finland
    Welcome to Priuschat. Prius has two batteries: 12v traditional car battery and high voltage drive battery. That 12v battery is relatively cheap (couple hundred) and practically any shop can replace it in no time. I presume it was this 12v battery that had been charged when car was storaged since normal DIY chargers can be used. You don’t get any reading of this 12v battery from the dasboard. When it’s done car simply won’t boot up and doors need to be unlocked with traditional key.
    The drive battery is completely different animal. Cost couple thousand but usually last very long if car is used normally. Being parked for several years is not normal. I highly recommend to have both of your batteries health checked at proper shop. Perhaps have whole car checked for safety sake (brakes etc) if car has been parked many years.
    Edit: drive battery charge go up and down during driving, it is normal. Car use the charge that is available and recharge during braking and by running the combustion engine when needed.
    #2 OptimusPriustus, Jul 30, 2024 at 7:29 PM
    49,542
    just over half capacity is normal, and dropping to 2 bars with engine cycling on and off to keep it there in stop and go traffic is also normal. and there may be times when the battery completely fills, depending on driving conditions.
    are you saying you have a 10 year old car with 4,000 miles? if so, that's wonderful!
  4. Eddie25
    Eddie25 Active Member
    373
    140
    IL
    The battery does charge itself when it gets low. The "hybrid" aspect of the car is that it uses a combustion engine and a high voltage battery in conjunction with each other. The battery (discharge) helps the engine and the engine helps the battery (charge). It's constantly going from high to low charge and back. If there are no trouble code lights or drivability concerns I wouldn't worry about it. Yes, it's OK for the car to sit with the battery at a low charge. It's not considered great for the battery if the car sits for an extended period, but like a week or so here and there isn't terrible.
