Battery condition
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Troy123, Sep 9, 2023.
  1. Troy123
    Troy123 New Member
    lakewood Ca
  2. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,788
    2017 Prius c
    Simply replacing bad cells is not enough.
    Then they ALL need to be charged and balanced, as much as possible.
    Is that picture from before the cells were replaced or after ??
    My guess is that at least one and maybe 5 more need to be replaced.
    But I'm not a fan of replacing any less than ALL of the cells.......because of exactly what
    you are seeing now.
    49,446
    did you clean/replace the corroded bars?
  4. Troy123
    Troy123 New Member
    lakewood Ca
    I replaced the bars yesterday,got as high as 80% charge.seams to be doing better
