Battery cooling fan maintenance
Discussion in 'Prius v Technical Discussion' started by 12n14V, Jul 11, 2017.
  1. 12n14V
    12n14V New Member
    SD CA
    Re general maintenance on Prius v wagon ...has anyone done a video on cleaning the cooling fan squirrel cage above battery? I'm have a problem taking apart the trim and covers to get it out of it's nook. The seat and trim are different than our regular G3 Prius
  2. rdgrimes
    rdgrimes Senior Member
    1,740
    446
    New Mexico, USA
    2018 Prius Prime
    Under normal conditions it doesn't do enough to warrant that type maintenance. Usually runs at pretty low speed.
  3. Sooner Al
    Sooner Al Active Member
    385
    340
    Oklahoma, USA
    2016 Prius v wagon
    FWIW I just vacuumed the small screen beneath the rear right side passenger seat this morning. I don't carry pets so there was little to barely noticeable blockage. We've had the car just over a year.
  4. EZW1
    EZW1 Active Member
    722
    Phoenix, AZ
    2016 Prius v wagon
    Four Touring
    I recently watched a UTube video about this very subject. Don't recall the title, but search on Prius V battery fan should get you there. I was quite good. They guy showed everything, including access to 2 clips UNDER the fan.
  5. icyrius
    icyrius Active Member
    238
    113
    Florida, USA
    2014 Prius v wagon
    I tried doing the same thing and only found this diagram related to my Prius V
  6. Mendel Leisk
    39,015
    Just a thought: it might be possible, and easier, to clean it without complete removal. Ours is 2010, so different though.
    If you've never cleaned, I'd be inclined to get to it at least once, regardless of how clean it might be, just for peace of mind.
  7. Andyprius1
    Andyprius1 Senior Member
    2,327
    859
    Cool CA
    I would say, a correct fitting brush and a good vacuum should do the trick. Even on my 2005 it was quite a job to remove the fan, there was also some ducting in there as well.
  8. Mendel Leisk
    39,015
    Dusting wands are good for the fan ductwork:
    Also good in the engine bay.
