Battery dead...and another thing
Discussion in 'Gen 2 Prius Technical Discussion' started by yanivz, Nov 18, 2017.
  1. yanivz
    yanivz Junior Member
    israel
    I was driving today my 2007 Prius when suddenly saw on the screen the message "Problem" followed by 4 horrible warning sings:
    1. Engine
    2. VSC
    3. Red triangle with warning sign in it
    4. Circle warning sign
    I've opend immediately "Vehicle Single Check Mode" and saw this:
    **when the vehicle was not "warm" it was 12.1
    rushed to "System Check Mode" i saw this:
    Finally after clicking AUDIO H/U (CHEK) i saw this:
    Please tell me what is the problem and how can i fix it? how can i remove those horrible warning sings?
    P.S the car is driving fine.
    Thanks.
  2. edthefox5
    edthefox5 Senior Member
    10,096
    4,804
    Clearwater, Florida
    All of those screens won’t tell you anything about your issue which is probably a bad hybrid battery. You need to have the car scanned by a hybrid capable obd2 code reader to confirm. It has throw a lot of codes,
    But you are probably seeing hybrid battery issues poor mileage battery goes to purple real fast.
    What’s the mileage?
    Data Daedalus likes this.
  3. Sam Spade
    Sam Spade Senior Member
    2,036
    1,023
    2017 Prius c
    12.1 is nearing 50% discharged and is NOT good.
    IF......the 12 V battery is old (5 years or more) then it would be a good gamble to replace it first before considering something more expensive.
    Even well qualified shops sometimes don't do a good job testing 12 volt batteries but a test wouldn't hurt.
    49,383
    how many miles/km on her?
