Battery dead but when tested it shows up as Good
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Ilovemystinkingprius, Mar 1, 2025.
  1. Ilovemystinkingprius
    dallas
    Went to start the Prius after a day of not driving and there was nothing left in the battery. Took the aux battery out of the back and got it tested at auto zone but they say it’s good. Not sure how or why this happened. I’ve seen some post about how doing a certain combination of things like lights on and opening the door can lead to a dead battery but none of that is applicable. Haven’t had any signs of the battery dying to begin with. Not sure if it’s time to replace the main hybrid battery, but I’d think there would still be a charge in the aux to at least unlock the car or provide some light when opening the door.
  2. JC91006
    16,651
    8,501
    if your dash didn't light up, it might be just a bad combination meter. This is a common failure on older Prius cars. You can tell if your car starts by pressing the start button and waiting about 10 seconds for the engine to kick on.
  3. ForestBeekeeper
    ForestBeekeeper Active Member
    765
    301
    Maine
    You are having issues with your 12vdc battery. I see no reason to bring your drive battery into the conversation.
    It could have been due to a loose terminal connection on your 12vdc battery.
    Mine has been drained empty one time when the rear hatch lid did not shut completely.
  4. Tombukt2
    Tombukt2 Senior Member
    11,994
    2,119
    Durham NC
    You're 12 volt battery can easily show 12 volts It just doesn't have anything behind the 12 volts If you were to short the battery terminals for say 10 seconds it would not recover the 12 volts immediately like a good battery would That's how you used to test the battery The LISLE battery tester was a silver box with these heavy cables without any covering on them and a button and you push the button and held it until the meter moved until the cold cranking amps were revealed on the scale and then you let the button go and if you were looking in the grill of this device you'd see those tungsten bars or whatever they are they turn almost red hot basically shorting the battery for 10 15 18 seconds depending on the CCA and then when you let go of that button it's supposed to recover the 12 volts immediately If it doesn't well it's no count.
    douglasjre and ForestBeekeeper like this.
  5. bisco
    51,014
    did auto zone give you a print out? how old is the 12 volt?
  6. douglasjre
    douglasjre Senior Member
    2,085
    698
    Null, NL
    Why do u think that is? What testing have you done?
  7. ForestBeekeeper
    765
    301
    Maine
    Our mechanic uses one of those to test a battery's Load capacity. It is much more accurate than a simple voltage measurement and gives you an idea of how many amperes the battery can provide.
    If you have reason to truly suspect your 12vdc battery, get it tested to learn its Load capacity.
    I find it kind of disheartening when I read so many people who at the first hint of a 12vdc battery problem want to jump on the drive battery. When there is no indication of an issue there.
    MAX2 likes this.
  8. bisco
    51,014
    He took it to auto zone, pretty sure they do a load test
    Tombukt2 likes this.
  9. Mendel Leisk
    40,456
    Get your own load tester? My pref would be Solar BA9 (have an older version). Autel and TOPDON are popular.
  10. Tombukt2
    11,994
    2,119
    Durham NC
    They do and it's with some algorithm on a computer that runs off 5 volts or something so there's always that a real test of a battery is to take two pieces of metal and short the battery A coat hanger works well It should light up that coat hanger red hot and it'll usually bust in the middle where it was bent before and when it does that and you put your test leads on it and it says 8 volts it's about that battery is no count If you put your test leads on it and it says 12.7 that battery is the shiznit. That's how you load test the battery or how it was done for 50 years and then everything turned into solid state electronics and computers and algorithms and as we see algorithm sometimes be not the thing.
