Battery dead?
Discussion in 'Gen 2 Prius Main Forum' started by 72randy, May 31, 2010.
  1. 72randy
    72randy New Member
    27
    Sherando, VA
    This morning we went out to start the car and we could not do so. I don't know how it happened but I think the battery is dead. We cannot open the luggage door or the two back doors of the car. I'm not sure what to do.
    If I call our road service company to get us started would they be able to do this? If this is not possible what do I do next? I see in the manual that I could possibly open the hatch door manually but since the two back door are locked I cannot do this either.
    If a road service group cannot help us get started, I expect that they could tow the car to the Toyota dealership.
    Any advice appreciated.
  2. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
  3. Patrick Wong
    18,210
    6,517
    To open the main relay/fuse box near the inverter, press hard on the latch in front of the box, then pivot the cover up. Then you'll see a red plastic cover over the dedicated positive jumpstart terminal.
    If you need to open the hatch manually, then read on.
    Enter the car via one of the unlocked front doors. Note the inside door lock handle that shows red, indicating the door is unlocked.
    Reach back to the back door, and manually unlock the door, looking for the door lock handle and moving it so that it also shows red. Now the door is unlocked.
    Then open the back door, lower the rear seat back, and crawl into the hatch area. Remove the folding hatch floor bottom. Remove the small access panel at the rear of the black plastic tray over the spare tire.
    Find the manual hatch release latch which is a little shiny metal lever, and open the hatch.
    Remove the hatch floor cover over the 12V battery, in the right rear corner. Now you have access to the battery, and can replace it or do whatever you need to do.
  4. JimN
    JimN Let the games begin!
    7,028
    1,117
    South Jersey
    Open the driver's door manually.
    Pop the hood.
    Expose the jump point as described.
    Hook up a charger.
    Try to charge the battery or start the car.
    Drive it to the dealer for a new battery. Don't turn the car off.
    Buy a battery.
    At 5 years you are past due.
