Battery died now right side display is black
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Linda57, Oct 20, 2023.
  1. Linda57
    Linda57 New Member
    Arizona
    My overhead lights stayed on all night so the 12v died. Joyfully ripped the rear stuff up in 100 degree sun to jump it off. Drove it around a little to get that charged back up. Now the right side of my display panel is black. Please tell me it is something simple and I can fix it myself. Thanks
  2. Brian1954
    Brian1954 Senior Member
    1,814
    719
    South Central PA, USA
    FYI, There is a jump point in the front fuse box under the hood that is easier to use than connecting at the 12v battery in the back. Look in the owners manual for more information.
  3. Tombukt2
    Tombukt2 Senior Member
    12,214
    2,155
    Durham NC
    What you may want to be doing here is putting the battery on a trickle charger. Let the battery charge up and then ascertain that you actually have around 12 and a half 12.4 volts standing after you unplug the charger come back and check it about an hour later If you're falling the voltage you need to rectify that then you may want to unplug the battery for about 5 minutes or so let the car just completely level off no charge completely dead and then reconnect the 12 volt and see what you got
  4. Linda57
    Linda57 New Member
    Arizona
    Thanks. Will check that if it happens again but that issue is done. Why is half my display panel black???
  5. Linda57
    Linda57 New Member
    Arizona
    The battery is fine now. Half my display panel is black. I only see the speedometer part right in front of me. The odometer and energy display is gone. What do I do???
  6. bisco
    51,155
    what voltage is the battery testing under load?
  7. Linda57
    Linda57 New Member
    Arizona
    i have no clue. I don’t have a tester. All I know is it starts but half the display screen is black
  8. bisco
    51,155
    another thing is to make sure nothing is on the dash in front of the display, blocking the mirror image of the meter
  9. Mr. F
    Mr. F Active Member
    386
    253
    Washington
    Could you post a picture?
  10. Brian1954
    1,814
    719
    I did some searching on this forum, and I read a few other threads where this happened. You need to fully charge the 12v battery. Driving it a little while will not fully charge the battery. The best thing to do is buy a small smart charger ( 1 to 4 amps) and use it on the battery for 18 to 24 hours to fully charge the battery. The other option is to remove the battery and take it to an auto parts store for a battery test and charge.
    How old is your 12v battery?
  11. ASRDogman
    ASRDogman Senior Member
    7,243
    3,781
    If you search online you'll find places that fix that. Sometimes it's a capacitor and
    other times it's a poor solder joint.
  12. bisco
    51,155
    you can get a free load test at auto zone
    Linda57 likes this.
  13. Linda57
    Linda57 New Member
    Arizona
    Thanks! Will go tomorrow
  14. Linda57
    Linda57 New Member
    Arizona
    Wasn’t able to try anything since Saturday but when I went out and started it today everything is fine! Thanks all for help(y)
  15. bisco
    51,155
    glad to hear it, all the best!
