Battery dies after I drive my daughter’s prius
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by donzoh1, Jun 24, 2021.
  1. donzoh1
    donzoh1 Active Member
    434
    149
    Lenexa, KS
    My teen daughter is the main driver of our Gen 2 Prius. She doesn’t have problems with it. But whenever I drive it or even just move it in or out of the garage, the battery will be dead the next time she goes to use it. I can’t figure out what I am doing that is different than what she is doing. I believe the lights are set to automatic.
  2. JC91006
    16,470
    8,383
    If the battery is over 5 years old and the car is not driven often, it's just a coincidence you get the surprise dead battery.
    After the dead battery episode, I would assume you just jump start it and go about your day again? Leaving the battery at a very low state of charge for the dead battery episode to repeat itself when you get in it the next time.
    If the battery is over 5 years old, change it out and you shouldn't have this problem again. Surely you were the main driver of this car before your teen got it, so you know how to operate it properly.
    48,943
    perhaps she is driving it further and it has time to charge a bit
    Priusjames likes this.
  4. donzoh1
    434
    149
    Lenexa, KS
    No
    No I bought it as a dead Prius and fixed it. Then instead of selling it gave it her to use, it gets driven pretty much everyday. The battery is dead “after” I drive it move it. I usually charge the battery with a battery charger and then she will drive it for a week or two without problems until I drive it again.
  5. JC91006
    16,470
    8,383
    There should be a date on the battery, my guess that battery is quite old. After a while, they just don't hold a charge for long, even after you charge it.
  6. bisco
    48,943
    didyou get the covid vaccine, you might be magnetized
    Landon51 likes this.
  7. dbstoo
    dbstoo Senior Member
    1,232
    660
    Near Silicon Valley
    2024 Prius Prime
    The only thing I can think of is a loose wire that your bigger feet are brushing (under the dash) or that your heavier butt is disturbing (in the seat).
  8. edthefox5
    edthefox5 Senior Member
    10,096
    4,795
    Clearwater, Florida
    No surprise the 12 volt battery is shot. One good deep discharge and will never be the same. You keep propping it up with charges.
    Remedial charges only helps a healthy battery.
    Everyone comes on here scratching there heads about the 12 volt battery,
    One voltage check at the front jumppoint will tell you what’s what.
    Healthy 12 volt battery lives at around 12.6 volts at the front jump point.
    A healthy 12 volt battery will not drop more than .5 volts with car off and headlights on and high beam. Your battery will fail both those tests.
  9. bisco
    48,943
    maybe the extra weight in the car causes fatigue
  10. Priusjames
    Priusjames Member
    92
    67
    Irvine, CA
    My experience, each time I've replaced the 12v battery, is I've literally said "I always forget how much better everything works in the Prius with a 12v battery that's never had to be charged" to my SO. She reminds me of it when I do it.
    If a Gen 2 12v needs charging, it needs replacing. I always wait and screw around charging it a bunch of times for a year or so...but I *always* recognize other things were affected too after the new battery is in.
    The car is telling you every time you get in. It's not telling her, it's telling you!
  11. TMR-JWAP
    TMR-JWAP Senior Member
    6,089
    5,806
    Columbia, SC
    First, is there an 'automatic' on the Gen 2? I thought it was merely on/off with auto off when they're left in the on position. I'll have to look, lol. anyway.....
    It could also be the order in which you exit the car/turn off the car while headlights are on.
    Do you open the driver door before or after you turn the car off?
    If I remember correctly:
    1. if you turn off the car first, then open the door, the car assumes you are finished with the car and it turns lights off.
    2. if you open the door, then turn off the car, it assumes you want to leave the lights on, so it leaves them on.
  12. donzoh1
    434
    149
    Lenexa, KS
  13. donzoh1
    434
    149
    Lenexa, KS
    Yes I got the vaccine. More correctly, I got a vaccine, J & J. I was actually in the J & J vaccine trial. I've recently received my first dose of Pfizer as I think it's more effective. So, I figured if anyone was magnetized, it would certainly be me. I was recently somewhat alarmed when I was able to make a paper clip stick to my forehead. However, I felt better when I tried the test again with a small amount of baby powder in between. No more sticky.
    Landon51 and bisco like this.
  14. ETC(SS)
    6,492
    If you have to charge a battery on a car that is regularly driven, then it REALLY needs to be replaced.
    FIRST thing I would do is replace the aux (12v) battery, especially if your kid drives alone a lot.
    I don't KNOW whether or not G2s have automatic lights, and since I do not know I would suggest turning them off after you use the car.
    Make sure that you're closing the doors all the way, not leaving the interior lights on, or any aftermarket electronics energized.
    All the usual suspects.
  15. edthefox5
    10,096
    4,795
    Clearwater, Florida
    To some regularly driven means going to the store 1 mile away and back and that’s it.
    Like many people here with bad 12s.
    Regular maintenance charges are a very good thing to do if you pay attention. See how long it takes the fully charged light to come on and note it.
    At the 3 year mark my yellowtop took forever to fully charge and is now on my sh*t list as my last yellowtop died fast at the 3 year mark.
    no more yellowtop for me. But if I did not test it I would never know.
