Battery dies within minutes
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by [email protected], Nov 16, 2011.
  1. mcazares@san.rr.com
    [email protected] New Member
    san diego
    On 2 occasions now my 08 Prius battery has died mysteriously and quickly. The circumstances were similar both times.
    I'd been driving in a parking lot for a while searching for a space. Then parked for about 15 minutes. Then started the car, but decided instead I needed to make a phone call. Maybe started the call while it was still running, but then turned car off (don't remember for sure). It was hot & the call was taking a while, so I rolled down the windows half way on driver & passenger sides. Then opened driver door for more air flow. After about ten minutes, I go to the start the car and it's DEAD! Both times had to call AAA to get a jump.
    After the first incidence I took it to Toyota dealer to check the battery, they said it was fine. Is there some bad combination of open door (light on), headlights on, bluetooth, proximity key & an ipod cable (just the cable) plugged into console that could cause the battery to drain in ten minutes???
  2. cwerdna
    cwerdna Senior Member
    12,544
    2,123
    SF Bay Area, CA
  3. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,512
    38
    Santa Fe, NM
    Have you replace the 12V yet? Problem is, it takes so long for the car to charge it, that a jump and go leaves you at high risk for having it go dead again. Best approach is to trickle charge the battery for several hours at 2-4 amps. If it dies again, just bite the bullet and get a new one.
