battery display how on your display
Discussion in 'Gen 2 Prius Main Forum' started by duanerw, Oct 16, 2005.
  1. duanerw
    duanerw senior member
    140
    lexington ky
    2013 Prius v wagon
    I purchased my Prius in jan this yr and in the battery display, i believe full would show 8 bars.Most of the time i get 6 bars and have seen 7 only a few times.
    Yesterday while at the gas pump another 2005 prius drove in and we talked a bit.we both have over 10,000 miles on our car and when she started it up i seen 7 bars.She said it has 7 bars on hers most of the time.
    I was wondering what to expect on the battery display as far as how many bars show up most of the time on other cars.
    also at one time you could view your posts but it dont seem to be there anymore or im blind in one eye and cant see out of the other...........
  2. LaughingMan
    LaughingMan Active Member
    1,386
    Marlborough, MA
    The battery level shown on your Prius's display reflects the charge left in the car's high voltage battery.
    What you usually see of about 6 or 7 bars is what's considered the sweet spot for the battery. The car's computer usually likes to maintain 6 bars worth of charge in the battery. If the charge gets high, to 8 bars, the computer will allow more use of electric-only mode to bring the charge down. If the charge gets low, to say 2 or 3 bars, the computer will use the gas engine more to recharge the battery back up.
    But of course, it depends on how you drive the car, and the conditions. If you're using a lot of power by running the A/C, the headlights, etc, all while using electric-only mode a lot, the battery level will drop. I've seen it as low as 1 or 2 bars.
    On the other hand, suppose you're going down a very long steep downhill. The car will use regenerative braking to slow you down, and will capture as much of that energy into the battery. Then you might see the magical 8 bars.
    The Prius is very smart... you can think of it's own battery management as a kind of homeostasis. It does it's best to keep enough charge in case you need the power, but not too much or too little that it would damage the battery.
  3. mmtt
    mmtt New Member
    Venice
    hello everybody.
    I was talking with a friend (owner's Prius as me) when I discovered that:
    driving normal (on highway, i.e.), his battery level is almost always 6 bars load, the traditional engine keeps battery pack load with 6bars.
    My battery (I've buyed a used one) level instead is almost always 4/5 bars....
    so my question is: could by battery back suffers any trouble? Maybe previous drivers have ill-treat my car?
    How can I discover if my pack needs to be changed?
    Thanks in advance for your answers (and sorry for worst english ;))
    Matteo
  4. CraigCSJ
    CraigCSJ Active Member
    287
    144
    San Bernardino, CA
  5. LaughingMan
    1,386
    Marlborough, MA
    Some variation may be due to how you drive the car too, or the terrain that you cover on a day to day basis.
    You probably don't take the same path as your friend to work everyday, so the battery state is not exactly going to exhibit the same behavior. Also, variation of 1 or 2 bars may just attribute to how you drive the car, or what accessories you have running normally.
  6. rogerSC
    rogerSC Member
    170
    I've noticed that sometimes when I would expect my car to be running at 99.5 mpg (running on battery), it will still be charging the battery. I'll switch over to the energy screen and it will show a green battery, but also an arrow into the battery. These are occasions when I'm going slow, about 25mph, and the battery seems charged enough that the engine shouldn't be running to charge it. And it should be able to be running on the battery since I'm not asking for the amount of acceleration that would normally turn on the ICE.
    Guess I need the EV switch, maybe that would give me finer control in the few occasions when I want it.
    Thanks.
    -Roger
  7. aaf709
    3,862
    2022 Prius Prime
    I get 8 bars from time to time, mainly when I'm going down a long hill. It doesn' t stay that way long.
  8. LaughingMan
    1,386
    Marlborough, MA
    I usually get that when the car is not warmed up yet. It happens less and less frequently the longer I drive it during one trip.
  9. coloradospringsprius
    171
    That sounds unusual. When our Prius gets to seven bars, it really wants to discharge the battery. It seems to prefer the four-to-six bar area.
    On a semi-related note, we visited Rocky Mountain National Park last week. It's the first time I'd ever seen the battery go from two bars, to eight bars, to two, and back to eight in just a few minutes' driving.
    Oh, and we saw some great scenery OUTSIDE the car, too!
  10. Patrick Stracko
    Patrick Stracko Junior Member
    Nazareth
    2020 Prius Prime
    Just purchased used Prime 2018...The battery display is green and blue...when charged, green is full to the top, then as it discharges, it goes down to the blue area but doesn't go any further...what is the purpose of the blue level (about 1/3 of the total battery indicator)?
    How do I know if the system is working properly...
    Thanks in advance....
  11. mr_guy_mann
    mr_guy_mann Senior Member
    3,487
    1,590
    NJ-USA
    I don't know since this forum is for the Gen2 (2004 to 2009) Prius. You might want to post your question in the Gen4 forum.
    Patrick Stracko likes this.
  12. Patrick Stracko
    Nazareth
    2020 Prius Prime
    Newbie mistake...thanks
