Battery drains fast in idle or without gas
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Matty803, Jul 7, 2020.
  1. Matty803
    Matty803 New Member
    United states
    So my battery power drains under like a minute idle and driving without using any gas with the ac on. It last a little bit longer with the ac and fan off but still dies fairly quickly. When i am using the engine it constanly chargers the battery and im driving and the battery hits 2 bars and the traction charge cuts on the engine like overloads and makes loud noises feels like its on the verge of breaking down. Now i cant run any diagnostics that come with car because my touchscreen was cracked when i purchased the car i can see everything just cant press the touchscreen buttons. What is going on? Is this my hybrid battery failing or could it be something else ? 12volt? Spark plugs? I dont have much money if any to put into my car right now what could be some options for me to reolve this ?
    I can keep the battery charged as long as im using the engine to charge the bat3rery while driving. But if it sit over 2 minutes it drains to 2 bars. If i try driving on the 2 bars with or without the engine it makes the loud noises the more i try to press the gas and wont really move and i have to stop or i feel like it would break down.*
    I also try driving in power mode as much as possible to get more gas and accelration to keep the engine charging the battery as much as possible so ot doesnt deplete 2 bars and do the auto low battery charge. Sorry im not very knowledgeable in the prius terms and lingo yet.
    #1 Matty803, Jul 7, 2020
    49,469
    it is impossible for us to know what the problem is, if any. what you describe sounds fairly normal.
    how many miles on your car?
    watch @NutzAboutBolts youtube on cleaning the egr circuit. you can do that for free.
    what is the service history?
    NutzAboutBolts and Mendel Leisk like this.
  3. Mendel Leisk
    38,717
    ^ This.
  4. edthefox5
    edthefox5 Senior Member
    10,096
    4,806
    Clearwater, Florida
    No one posts there mileage on this site. Its like going to the dentist and refusing to open your mouth.
  5. fotomoto
    fotomoto Senior Member
    5,602
    3,778
    So. Texas
    Hmm, so how long have you owned this car?
    It's certainly not uncommon for folks to sell, trade-in, etc a hybrid when the HV battery begins to have issues. And yours sounds like it is showing one of the classic signs of weakening but hasn't failed yet (tripped the error lights/notifications).
    There are several avenues: keep driving it, look into grid charging, save up for a new HV battery, repair the original or replace it with a rebuilt one. Every owner of an older hybrid with the original battery will face this; it's not a matter of if but when. Yours may still be under warranty but it will need to have the necessary codes before Toyota warranties.
    GOOD LUCK!
    kenoarto, Matty803 and jerrymildred like this.
  6. Matty803
    Matty803 New Member
    United states
    177856 miles. Had it over a year. Havent had any problems with it until now
    I saw there are individual cells for sale online about 30 a piece. What would be a cheap easy way to test out the cells ?
    I dont believe its under warranty anymore
    177857 only had oil changes and struts replaced never had any issues
    Ive owned it over a year. Is there a cheap way to test the hybrid battery cells?
    #6 Matty803, Jul 8, 2020
  7. AzusaPrius
    AzusaPrius Senior Member
    1,875
    822
    Give it some time Im sure someone will tell you to just buy a new pack from some site. Around here they seem to call it whack a mole and it saves a lot of money. Watch YouTube and see if you can do it then order from ebay.
  8. Raytheeagle
    Raytheeagle Senior Member
    11,251
    15,481
    Bay Area, California
    2019 Prius Prime
    Now you have a mask on so opening your mouth gets the same result:p.
  9. fotomoto
    5,602
    3,778
    So. Texas
    But it doesn't save a lot of time which for many people is "money".
    The wack-a-mole process can takes many days or even weeks to complete and is really only a viable solution for those who have other means of transportation, don't need to drive, or don't mind the lower reliability of a repaired pack and repeating module failures down the road. Using cheap multiple "hobby" chargers can take even longer.
    Fast, light, cheap. Pick two.
    Matty803 likes this.
