Battery dropping to low purple on start up
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by gazoo6045, Mar 21, 2017.
  1. gazoo6045
    gazoo6045 Junior Member
    covina
    when i turn on my 06 prius in the morning i i have 4 bars that are blue. as soon as i turn on the heat the bars drop to one bar of purple within thirty seconds. is this normal?
  2. JC91006
    16,482
    8,400
    That's not normal, you have a weak battery. Need to charge and balance before it fails
    Samprocat and Kramah313 like this.
  3. gazoo6045
    covina
    just changed to rebuild battery....last week..
  4. Sam Spade
    Sam Spade Senior Member
    2,036
    1,023
    2017 Prius c
    Hope it has a warranty.
  5. JC91006
    16,482
    8,400
    Doesn't sound like it was rebuilt, sounds like someone swapped a module and didn't charge and balance
  6. bisco
    49,492
    what company did you get it from?
  7. uart
    uart Senior Member
    4,215
    1,201
    Australia
    Not a good sign for a "new" battery, however pretty much standard fair for an old worn battery. I've got a 2005 model with 300,000 km that's still on the original battery, and mine will do that every time unless I let it warm up for about 45 seconds before driving.
    Other than that mine drives perfectly and still gets great fuel economy. So I just let it warm up for a minute before driving in the morning, no more purple one-two bar battery issue.
    Before the cats get up to temperature the Prius tries to use the battery more than the engine, so it takes a bit of a beating in the first 60 seconds of driving if you don't let it warm up. Traction batteries in prime condition cope with it ok, old warn ones not quite so well.
  8. Sam Spade
    2,036
    1,023
    2017 Prius c
    While it is somewhat sad, those opting for a "rebuilt" battery should ask EXACTLY what the word "rebuilt" means to that supplier.
    There is no standard definition.
  9. JC91006
    16,482
    8,400
    The fix is simply to charge and balance. Nothing really too complicated
    jerrymildred and Samprocat like this.
  10. MTL_hihy
    MTL_hihy Active Member
    536
    261
    Maritimes, Canada
    Modules probably need to be grid charged then load tested to ensure all is well of that battery was recently rebuilt.
  11. JC91006
    16,482
    8,400
    Well it is what it is, charge and balance and hope for the best. If OP is going to take it apart again, he should test everything and clean the bus bars too
  12. 'LectroFuel
    'LectroFuel Senior Member
    880
    673
    San Juan Capistrano, CA
    By charge and rebalance do you mean something like a Prolong reconditioner? Do those work well?
  13. JC91006
    16,482
    8,400
    Yes and yes
  14. jerrymildred
    jerrymildred Senior Member
    11,511
    14,113
    Tampa, FL
  15. MTL_hihy
    536
    261
    Maritimes, Canada
    jerrymildred likes this.
  16. sandman
    sandman Member
    277
    32
    kentucky
  17. jerrymildred
    11,511
    14,113
    Tampa, FL
    I would think it would help. Not sure how much it would get you long term with that many miles. Maybe @jeff652 will be able to give you a better idea. I think it would depend on how bad any particular cell is. If it's just badly out of balance, I'd expect it to help quite a bit if you do the full reconditioning routine.
    Edit to answer the other question: It's not very hard at all if you're reasonably handy. You have to take out some panels to access the battery and its fan. There's a little controller box that you have to wire into the cable to that fan. And, of course, you have a couple wires to connect to the battery pack. It'll probably take a couple hours if you haven't done it before.
  18. dolj
    dolj Senior Member
    7,657
    3,869
    Wellington, New Zealand
    Specifically for this situation, try letting the car sit in READY (with HVAC off) and wait until the ICE shuts off which takes about 50 seconds. It seems like a lot longer, but if you time it you will see that is ~50 secs. This signals moving from stage 1 to Stage 2 of the Prius engine warm up cycle. (Read one about the 5 stages of Prius warm up in my sig.)
    Why this may help, is that during stage 1, the Prius almost exclusively tries to use the electric motor to propel the car, so that the ICE can be configured in a very inefficient (fuel economy-wise) but hot running configuration to get the initial engine temperature up quicker. Because it uses the electric motor to propel the car, it draws heavily on the HV battery, and if your HV battery is at the poor end of the scale, it is quite taxing on it. If your HV battery is at the good end of the scale, it has no problem propelling the car, as it is designed to do. YMMV.
    hope this helps.
  19. sandman
    sandman Member
    277
    32
    kentucky
    Okay, battery getting much worse. It's staying in purple(SOC is 20-35)most of my commute on interstate ( 70 miles). when I get off interstate it comes back up in the blue. Motor really struggles on hills, I am afraid its going to blow. Worse in the morning when its dark. Here are my options
    1. I called dealership they quoted me a price of $3700 out the door for new hybird battery.
    2. I called around, and a few junk yards have them for $850(2009 114,000)
    3. Trade it in for a new 2017 Prius Three (Blizzard Pearl).
  20. uart
    uart Senior Member
    4,215
    1,201
    Australia
    It appears that you're driving your Prius too hard for it's current age and condition. If the SOC is staying in purple for most of your 70 mile interstate commute then it means that the engine is just not getting enough opportunity to charge the HV battery. All of the power that the engine can muster is being commanded (by you) to go to the wheels, so none goes to the battery.
    Even with a brand new HV battery, it can only cover for lack of engine power for a limited amount of time and then you're still going to end up with low SOC if the engine can't provide enough power.
    A new HV battery will definitely help, but it might not completely solve your issues if the engine is genuinely sick (low on power).
    As a temporary measure can you try warming engine for 45 sec to1 minute before driving as I suggested above. And try driving just a few MPH slower and pushing it less up hills.
