Battery ECU part #s
Discussion in 'Gen 2 Prius Main Forum' started by OldMage, Aug 24, 2023.
  1. OldMage
    OldMage RWD Celica freak, Prius "collector"
    31
    Spokane, WA USA
    2001 Prius
    How critical is matching the ECU part # when a replacement is needed. I have a 10/2005 that I've just swapped 3 cells, then discovered scorched ECU socket/pins.
    My ECU's part # is 89890-47080. Most of the available replacements on eBay are -47090/91/92. Are these superseding #s?
    Thanks,
    OldMage
    01, 02, 03, 06?, 14 C
  2. Tombukt2
    Tombukt2 Senior Member
    12,193
    2,150
    Durham NC
    From my experience on the Gen 2:04 to '09 the later model the better I believe in my '04 I had an '08 or '07 orange plugged still battery ECU under the hood in the back under the battery hood so I think you're good there so pretty much anyone you can get from generation to should be the same I don't think any wiring changed at the battery per se. Other things did change up in the dashboard dimmer switches and the like won't fit in the '05 after '06 most of the stuff won't go on an '05 and lower.
  3. OldMage
    31
    Spokane, WA USA
    2001 Prius
    I sure hope it works that way.
    This is where I get worried again, with it being such a late '05. I've gotta double-check the title but I think it's registered as an '05, not an '06.
    Tombukt2 likes this.
  4. Tombukt2
    12,193
    2,150
    Durham NC
    Just use the door panel date like on the old RA 65s that's what's important if yours is an early '06 then you have the 1 mm longer fenders and you have the smaller plugs on a lot of things in the dash The stuff is wired the same they changed the buttons the dimmer and some of the switches and they just won't plug up but the same color wires It's kind of weird I'm not sure why they did that because I guess they wanted to use newer plugs or something.
  5. Tombukt2
    12,193
    2,150
    Durham NC
    Tomorrow I can compare my '09 to my '04l and tell you quick fast in a hurry
  6. Tombukt2
    12,193
    2,150
    Durham NC
    I sent you a couple messages in the chat area of this Prius chat Good luck
  7. OldMage
    31
    Spokane, WA USA
    2001 Prius
    Everything RA65 was my world for so long. I still have mine (Sept '82 GT-S coupe), but it needs much love to make a comeback.
  8. dolj
    dolj Senior Member
    8,209
    4,180
    Wellington, New Zealand
    Yes, they are. 47092 is the latest version and replaces 89890-47080.
    I hope that it goes without saying that you replaced the No. 2 frame wire (82165-47040) as well. That looks nasty.
  9. OldMage
    31
    Spokane, WA USA
    2001 Prius
    Fantastic! Thank you!
    I am ordering both. Yes, yhe harness plug is "well done". Was teasing my son he bought a rare "Hibachi Edition".
