Battery ECU secrets and teardown (warning: geek content)
Discussion in 'Gen 2 Prius Technical Discussion' started by pEEf, Oct 23, 2010.
  1. pEEf
    pEEf Engineer - EV nut
    720
    579
    Berkeley, CA
    I'm presently working on an outright replacement for Toyota's Battery ECU for my PHEV project. I'm sure others are also curious, so here's my initial teardown and analysis of the hardware:
    The ECU sits on the end of the CAN bus, so it has a 120 ohm termination resistor. (on bottom of board) The Battery ECU has no other communication systems.
    The Battery ECU monitors the Traction battery main voltage along with 13 tap points spread evenly along the pack. This is done to detect pack balance. Battery Current in/out is also sampled using a hall-effect current sensor, and this signal comes on on pin C-15. This is used internally for "coulomb counting" to keep track of battery state-of-charge (SOC). There are 4 Battery temperature probes that use temperature-dependent resistors, and finally the battery fan voltage is sampled.
    The ECU also controls the Battery Fan Relay, and outputs a PWM signal to that is used by the fan motor controller to adjust the speed. There are no other control outputs used, but of interest is an additional 1A output that sits unused. (pin A-11) There are also several additional inputs that are also not used in this application.
    They use little optically-coupled solid state relays to select which of the 14 battery voltage taps they wish to read, and then use another pair as a switched-capacitor sample system to preserve electrical isolation. It's interesting to note that this board was designed to support 6 additional voltage monitor taps. (components not populated however)
    Note that the Battery ECU does not control precharge or the main battery relays, that is done by the Hybrid ECU.
    There is a 4K non-volatile EEPROM on this board, and in addition the microcontroller memory remains powered up at all times unless the +12v battery is disconnected. It doesn't seem as though SOC is stored in the EEPROM, as it seems to go to an arbitrary value if +12v is lost. This then begs the question as to what is being stored in there?
    I have not yet determined the microcontroller used, as it has house markings. It's similar to models offered by Fujitsu, so this is a possibility. I am not sure if it contains a masked ROM or flash, but there is a high probability it's Masked ROM. I will need to decap the part to inspect the silicon directly if we are to learn more.
    FYI: You may repost this picture and text only if credit is properly given.
    cdoroc, TheLastMojojomo, R-P and 19 others like this.
  2. pEEf
    720
    579
    Berkeley, CA
    For reference, Here is the simplified schematic of it's wiring in the Prius:
  3. Patrick Wong
    18,210
    6,511
    1. Is it possible that this board was also used for the Classic traction battery ECU which had 19 module pair voltages to keep track of?
    2. I am wondering whether the EEPROM stores the logical rules that determine which DTC are posted when the traction battery ECU detects incorrect operation (for example, uneven SOC, a ground fault, or faulty ECU operation?)
  4. pEEf
    720
    579
    Berkeley, CA
    While I know little of the Gen 1 system, I was under the impression that it did not use the CAN bus for these communications. If that is indeed the case, then it couldn't have been this board. It's possible though that Denso designed it for use with the Gen 1 pack, which later in the design cycle was shortened.
    Yeah, my first guess was that it is used to store the DTCs as well. It's just a theory at this point, and I'm not too concerned with figuring it out, as for my purposes it's not relevant. Still, if you wanted to determine this, the serial data between the micro and the EEPROM could be easily monitored to see what read/writes are being done, and when.
    Any Gen 1 geeks care to comment on the architecture of the battery ECU? (Bob? :) )
  5. vertex
    vertex Active Member
    672
    144
    new york
    2018 Prius Prime
    I don't know if this helps. I started to draw the schematic months ago, and got this down. pEEF did you find a data sheet for the opto devices?
  6. hill
    8,910
    I'm looking forward to your findings!
    :thumb:
  7. ken1784
    ken1784 SuperMID designer
    2,943
    1,384
    67
    Yokohama, JAPAN
    A-11, A-3, A-22 and A-23 are used by the external THS charger.
    http://www.autoshop101.com/forms/Hybrid15.pdf
    Ken@Japan
    4 people like this.
  8. pEEf
    720
    579
    Berkeley, CA
    Thanks Ken,
    But I didn't see any reference to those pins in that document. How do you know this, and do you have a schematic or some other diagram that shows how these connect?
  9. pEEf
    720
    579
    Berkeley, CA
    Thanks Vertex! Yeah that switched-cap circuit is pretty neat! If I get the time, I may finish your schema.
    I didn't find the full datasheet, but there is enough to understand how they work.
    Here's the part # breakdown and the specs: Panasonic AQW PhotoMOS Relays
    Here's a spec sheet: Panasonic AQW PhotoMOS Relay Catalog
    I'm sure Panasonic will give you the Datasheet if you ask them, but there's really no need.
  10. ken1784
    2,943
    1,384
    67
    Yokohama, JAPAN
    The THS Charger is Toyota's proprietary design and I've never seen its detail information.
    But, following is the block diagram shown on the Japanese Repair manual.
    Ken@Japan
    3 people like this.
  11. pEEf
    720
    579
    Berkeley, CA
    Interesting! This is useful, as it shows that the Battery ECU shuts off the external charger. They clearly show a relay in there!
    Could be useful for those that are adding in extra Prius packs and wish to to a minor plug-in PHEV.
  12. pEEf
    720
    579
    Berkeley, CA
    BTW, someone asked if I would do a similar analysis of the Hybrid ECU. If someone is willing to send me one, I'd be happy to! (I don't really want to take the only one I have out of my car)
  13. imwoody36
    imwoody36 the prius parts guy
    143
    116
    southern Indiana
    how many do you want?
    pm me.
  14. pEEf
    720
    579
    Berkeley, CA
    I had a look at the Gen I battery ECU, similar functions but implemented way less efficiently and much higher component count. I don't see the need to do a more in-depth analysis at this point.
    Next is to do a Gen III. Anyone have one they care to donate yet? I'll even settle for some good pictures.
  15. Storm123
    Storm123 New Member
    CA
    Battery ECU messages
    if it does not communicate, then what is the source of these Battery ECU messages:
    eaa-phev.org/wiki/Prius_PHEV_TechInfo#Battery_ECU_messages
    Confused :confused:
  16. uart
    uart Senior Member
    4,220
    1,211
    Australia
    Re: Battery ECU messages
    The CAN bus.
    Other than the CAN bus. I really can't see the source of your confusion?
  17. mrbigh
    3,686
    699
    Long Island, NY
    With only 2 post, what else can you expect? a greenish newbie....
  18. Storm123
    Storm123 New Member
    CA
    The CAN bus is not the source, it is only the communication bus used to transfer the messages from the source.
    The claim was made that the Battery ECU does not have any communication means and that it simply is used to electrically terminate the differential CAN bus.
  19. uart
    uart Senior Member
    4,220
    1,211
    Australia
    Absolutely not. The claim was made that the battery ECU was on the CAN bus but it was physically at the end and therefore had the termination resistors. There is absolutely no reason that it cannot be both "on the CAM bus" and also be the termination.
  20. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    Never argue communication protocols with a person who has chosen UART as a handle.
    Universal asynchronous receiver/transmitter - Wikipedia, the free encyclopedia
    JPR, R-P and cwerdna like this.
