Battery failed
Discussion in 'Newbie Forum' started by Nickchatty93, Mar 26, 2018.
  1. Nickchatty93
    Nickchatty93 Junior Member
    Lancaster, CA
    Hey everyone, I have a 2007 with 151k miles and its wonderful and have never had a problem with it, well I hit a rock, about the size of your palm, it shot up into the undercarage and it was very loud and 5 seconds later all the lights on the dash went on (triangle, check engine,etc) and the hybrid battery died fast and the fan in the rear was very loud, I towed it Toyota and they said I needed a new battery ($2200 otd) I told them I hit a rock and I think it damaged something but they said this is what the scanner says and we don't see any visible damage under the car you need a new battery. I was thinking of taking it to a craigslist hybrid shop in LA but I'm about 100 miles away and really am worried about getting it fixed like that. Would you suggest doing this or get one remanufactured or rebuilt. I have no idea what to do, I'm the farthest thing from a mechanic. The codes are P3000 and PA080. Thank you for your help amd watch out for large pebbles !
  2. ericbecky
    ericbecky Hybrid Battery Hero
    4,371
    3,222
    Madison, Wisconsin
    I would want to have a second opinion.
    A mechanic who has access to Toyota diagnostic tools.
    You may be able to look at basic hybrid battery info like voltage etc yourself if you have an Android phone/tablet and spend $30 on a scanner and the Torque app. (Can by scanner online and get in a few days)
    Would be happy to walk you through it.
    I would want to see real data or error codes that shows the pack is bad before spending the money.
    For example, it shows section 8 is failing. Or communication error, etc.
    RCO, Raytheeagle and jerrymildred like this.
  3. Nickchatty93
    Lancaster, CA
    Thanks for the reply! I'll buy the app today. It sounds unbelievable this rock did this but it was a second after! I would love your assistance and I will let you know when I get those codes. Thank you !
    RCO and Raytheeagle like this.
  4. fotomoto
    fotomoto Senior Member
    5,602
    3,779
    So. Texas
    My gut feeling is the rock incident is just a coincidence. The battery is firmly located inside the vehicle out of harms way and those codes are for the battery itself. You can do a hard reset/reboot yourself by disconnecting the 12v for a minute, reconnect and restart the vehicle and see if the codes come back. If you're still on the original battery, then it's suspect.
    GOOD LUCK!
    RCO likes this.
  5. ericbecky
    4,371
    3,222
    Madison, Wisconsin
    I would want to read the codes before clearing them. Just to be sure.
    Then peek at live data.
    And hen clear the codes.
  6. jerrymildred
    jerrymildred Senior Member
    11,516
    14,120
    Tampa, FL
    I agree. Codes are good. ;)
    Raytheeagle likes this.
  7. Nickchatty93
    Lancaster, CA
    What do you think? Good news hopefully
  8. Prodigyplace
    Prodigyplace Senior Member
    11,696
    11,318
    Central Virginia
    There is a problem in block 7 of the battery. Without seeing how the individual modules perform under load conditions it is difficult to determine the condition of the other modules.
    If you are paying to have a battery installed your best choice is a new Toyota battery. Any other brands are just failed batteries repaired with modules from other failed batteries. Most times they do not properly balance and test the battery packs.
  9. fotomoto
    5,602
    3,779
    So. Texas
    You have a failed hybrid battery; block number 7 is the culprit.
    You can (in order of cost and reliability):
    Replaced failed module with another module
    Purchase Grid charger and see if it "repairs" #7
    Purchase a rebuilt/repaired battery from numerous sources
    Purchase a rebuild kit consisting of new, 3rd party chinese modules
    Purchase a new Toyota battery
    GOOD LUCK
    RCO likes this.
  10. Nickchatty93
    Lancaster, CA
    Og
    Off to Toyota to spend my life savings! Lol thank you sir
    Prodigyplace likes this.
  11. Nickchatty93
    Lancaster, CA
    Dangit, thank you. Should I disconnect the battery and see if anything changes or it's 100% a bad battery?
  12. fotomoto
    5,602
    3,779
    So. Texas
    Shop around; the lowest price posted so far has been $1650 plus installation. Some dealers charge A LOT more.(n)
    Edit: also try contacting Toyota about a goodwill warranty. Being in California, you aren't too far out of expiration.
    #12 fotomoto, Mar 26, 2018
    RCO likes this.
  13. fotomoto
    5,602
    3,779
    So. Texas
    It may allow you drive it a bit before it triggers and goes into "turtle mode" again but otherwise you already have the codes and data.
  14. bisco
    49,513
    $2,200. is a great dealer price.
    christiw5, RCO and Raytheeagle like this.
