battery FAN problem
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by tomy, Jun 16, 2019.
  1. tomy
    tomy Junior Member
    europe
    hellow, my battery fan work just when connected OBD with hybrid assistant app, if not connected fan is sleep. outside temperature 30C, what is problem can you help?
    and car battery internal resistance is 0.023-0.027ohm its normal?
  2. jerrymildred
    jerrymildred Senior Member
    11,508
    14,109
    Tampa, FL
    Sounds normal to me. The fan is controlled by an ecu that is monitoring the battery temperature. How hot is the battery?
    Dxta likes this.
  3. Dxta
    Dxta Senior Member
    1,932
    766
    Lagos
    As long as you don't see the red triangle light, when you removed the obd2 with the fan "sleeping", the car's ECU would take care of the rest.
    But from the resistance vues, appears the battery is getting hot already.
  4. tomy
    tomy Junior Member
    europe
    Battery temp. Is a 35-41 C
  5. Mendel Leisk
    38,651
    On my third gen, pretty sure the fan was coming on, maybe speed one or two, around 35C battery temp. It's been a few years since I monitored, so not sure.
    There's some blower motor troubleshooting info in the attached. I've only skimmed, but hopefully will help.
  6. bisco
    49,386
    how are you determining if the fan is coming on or not? don't go by sound
