Battery filter for prime?
Discussion in 'Gen 5 Prius Care, Maintenance and Troubleshooting' started by Templeton, Jan 4, 2025.
  1. Templeton
    Templeton Member
    205
    55
    usa
    2024 Prius Prime
    SE
    Folks on this forum say that there is no user serviceable traction battery filter for the gen5 prius prime. And me looking at the rear passenger footwells seems to confirm that, as no vents appear to be there, on either side. (Although, interestingly, the current rav4 prime does have such a filter on one side.)
    But then I look at this toyota service manual and it seems to contradict this (see image below). So I am a bit confused. What am I missing here?
    scotched likes this.
  2. RandyPete
    RandyPete Active Member
    374
    155
    Santa Margarita, CA, USA
    2024 Prius Prime
    XSE
    Generic service manual for several models, not just the prius prime.
    Can you find that filter on your Gen5 Prius Prime ?
    #2 RandyPete, Jan 4, 2025
  3. BiomedO1
    BiomedO1 Senior Member
    2,651
    1,419
    SacTown, Ca
    I've shaken-out the filters on my gen4 Prime several times already. They're never dirty, but if you've pets riding with you - they could get dirty.
  4. Trollbait
    12,271
    That might be a filter for the onboard charger. IIRC, a part diagram showed it having venting, and it sits under the rear seat.
  5. Templeton
    Templeton Member
    205
    55
    usa
    2024 Prius Prime
    SE
    No, per the OP, it's not in our gen5 prime. Or certainly not in the place shown in the manual image.
    I totally understand the generic manual situation, but this page is specifically labeled prius prime. Which makes this all quite puzzling.
  6. KMO
    KMO Senior Member
    1,791
    581
    Finland
    2023 Prius Prime
    But that isn't 'specifically labelled' - every page fetched says Prius Prime, right? Model-specific information is marked with model codes.
    And even then they won't bother necessarily for an entire section. There's an implicit 'if present' on all entire sections.
    I'd only find this puzzling if it was in a wider context where there would need to be a 'this isn't always present' indication. Like a parts diagram, wiring diagram or wider disassembly procedure.
  7. vvillovv
    vvillovv Senior Member
    4,316
    1,495
    NY
    I'm not going to comment on the Gen 5 prime, but the Gen 4 Primes battery pack air inlet grilles are located up between the rear seat back rests and the rear doors ( both sides ).
    Gen 4 also has an inlet below the back seat near the floor providing air circulation for the hybrid battery charger on the passenger side. AMDs CarCareNut youtube channel has a video showing how to remove the grilles and clean the filter (if it needs cleaning).
    I didn't know about those filters until I saw that video a year or two ago.
    Don't worry too much about having trouble understanding the manuals, It takes a while to figure out some of the ways they are cross referenced.
  8. bisco
    50,881
    i thought gen 5 was liquid cooled
    RandyPete likes this.
  9. Trollbait
    12,271
    It is with refrigerant, and I believe outside the cabin space.
  10. bisco
    50,881
    then what would a filter do?
  11. Trollbait
    12,271
    Why there isn't one.
    The manual page cited seems to be in error.
  12. RandyPete
    374
    155
    2024 Prius Prime
    XSE
    The Gen5 Traction Battery is liquid (refrigerant) cooled and heated. The Traction battery charger may be air cooled with a fan. I could not find an air duct or filter for the Traction Battery Charger air cooling fan.
  13. Hammersmith
    Hammersmith Senior Member
    1,906
    1,898
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Toyota uses the same repair manual for both the Prius and Prius Prime(or PHV). The reason is says Prius Prime in the 'Model' section is because that's what was selected when the user searched for the repair manual. If you search using Prius, it will say Prius; if you search using Prius Prime, it will say Prius Prime. But both searches take you to the same document.
    If there are major differences between the two models, there will be subsections for each. For example: HV Battery(for HEV Model) vs. HV Battery(for PHEV Model). But the repair manual doesn't bother to do that for the Maintenance section.
    RandyPete and Templeton like this.
  14. Trollbait
    12,271
    In short, the battery filter pictured is for the hybrid that has the battery under the rear seat.
