Battery for Gen 3 remote
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by SubCode, Apr 12, 2017.
  1. SubCode
    SubCode Senior Member
    731
    1,338
    Getting battery low..on dashboard, What kind of battery is needed for the open the door etc..remote...and how do you open the remote..?
  2. DonDNH
    DonDNH Senior Member
    1,711
    654
    Nashua, NH
    Four Touring
    the battery is a CR-2032 (I think).
    Remove the metal key from the fob.
    gently pry apart the 2 halves of the fob.
    replace the battery
  3. xliderider
    xliderider Senior Member
    7,869
    3,116
    Honolulu, HI
    CR1632 is the one you want. Buy the double pack if available, it's cheaper and you should change them in both fobs anyway.
  4. jerrymildred
    jerrymildred Senior Member
    11,508
    14,110
    Tampa, FL
    CR1632 confirmed. I just opened mine to look. Much easier, btw than the Gen 2 fob. Push the button on the side that says, "Push." Then use the end of the key that pulls out to pry open the case. Battery is under the circuit board.
  5. SubCode
    731
    1,338
    Xliderider, Jerry and Don..thanks!
  6. marlinsmobile
    marlinsmobile Active Member
    106
    131
    Sandy Springs (Atlanta), GA
