Battery Issue, engine quits.
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Stephen Ervin, Feb 21, 2021.
  1. Stephen Ervin
    Stephen Ervin New Member
    Clovis Ca
    OK...I hope I have posted in the correct place. 2011 Prius 52,000 miles. 12 Volt battery died, replaced with a new battery from Toyota. The car will start with the start button held in. It will run for a few minutes and then die. Curiously it will start again if the gas pedal is firmly depressed. This is the second time I have had this issue, last time was two years ago.. Last time the vehicle was towed to the dealership and fixed within an hour. Total charge was 90.00 so it was not major. I never got straight just what was "reset". I have tried an electronic reset by disconnecting the negative to the chassis. I have also checked the HV disconnect. The hybrid battery indication is charging while the engine is running. What am I missing here?? Any suggestions would be appreciated!!! I do not have a code reader.
  2. tankyuong
    tankyuong Senior Member
    1,555
    662
    Central MO
    Test the new battery voltage.
  3. davecook89t
    davecook89t Senior Member
    1,092
    826
    Washington State, Florida
    Four Touring
    @Paul Schenck is nearby and might be able to help you. You need to have the codes read.
  4. rjparker
    rjparker Tu Humilde Sirviente
    10,469
    6,564
    Texas Hill Country
    Are you saying it loses your Ready state? And then is you press the gas, it goes back to Ready? If Ready is active during the sequence and you are talking about the engine cycling on and off, that is normal for a hybrid.
    davecook89t likes this.
