Battery level at 30% when i picked up my Prius after car detailing
Discussion in 'Gen 3 Prius Main Forum' started by Roger T, Jul 29, 2016.
  1. Roger T
    Roger T Member
    198
    48
    MA
    I went to pick up my Prius after around the 4-hour interior detailing appointment. My Prius got a external automatic car wash then it got the internal detailing. The battery level is at 30% when i turned the car on. I suppose if the gear is In Drive or Park mode, the Prius will recharge it self back to 50% if it goes under 40%. A/C was on.
    Does people who works on cars like to put car in Neutral (NOT Park)? Has anyone experienced low-battery scenario like this one? What level of discharge will harm the battery?
    Has anyone tried putting the Prius into Neutral with the A/C for an extended amount of time? What would happen?
    #1 Roger T, Jul 29, 2016
  2. wjtracy
    wjtracy Senior Member
    11,361
    3,606
    Northern VA (NoVA)
    Pretty typical for a Gen2 to get into the purple (2 bars) just sitting in PARK with A/C on. Pretty typical for shop work to run the batts down, leaving doors open etc
    Jrlennox74 likes this.
  3. Roger T
    Roger T Member
    198
    48
    MA
    Does that risk draining the HV battery though? What will happen if I put my car into neutral for extended amount of time and the SOC goes to 0?
  4. Kramah313
    Kramah313 Active Member
    408
    322
    Dallas, TX
    It should not go under 40% on its own...maybe they drained it in the car wash part in neutral down under 30%, then moved it 100 ft to the detailing area and shut it off before it could recharge further. From what others have said (I haven't gotten mine under the two bars or about 38% yet) it must have been screaming at them for a recharge after the car wash when they went to move it. I doubt one discharge to 30% will hurt it, just glad it didn't go down so far it couldn't start the car to charge it back up.
    To answer the question about what will happen if it runs down, the car will be unable to start and it will have to be towed to a dealer, where it will be recharged with a special machine. That would probably not be good for its longevity.
    Another way to get it in this condition is if you attempt to drive the car too far after it runs out of gas. Without the ICE available to charge it up it can run itself down below the critical charge level to restart the car.
    Roger T likes this.
  5. WilDavis
    WilDavis Senior Member
    2,493
    2,154
    49
    I notice that if I have the A/C on when I'm sitting in the car (2009 Gen II) with the system in "Ready", using phone, texting or whatever, the bars will quickly go down to 2 Purples (43-47.5%), but a quick drive around the block soon gets it back up to 7 Greens (64-77.5%); I don't know what they do when they service the car, but when I take it through the car-wash, the operators tell me to leave it in "N" and I notice that if the A/C is on, the SoC will go down quickly, but I've never agonised too much about it - I trust that the engineers at Toyota have designed the system to work under all manner of conditions (…damned clever, those Japanese! :eek:)
  6. Roger T
    Roger T Member
    198
    48
    MA
    In fact I remember when I picked up my car after the service to put a new tires a year ago, the SOC of the battery was 28%! I hope they did not drain the battery too much.
    Just now I did a test myself by shifting the gear to Neutral with the AC on. The car battery drained down to 30% from 60% really quickly with the AC on. I did not drain it further than that fearing it may harm the battery.
  7. Kramah313
    408
    322
    Dallas, TX
    On my gen 3 with moderate ac use (compressor at 2 or 3 amps, not blasting ac which can be up to 10 or more), it takes some time to get to 40% and kick in the engine from 60%, at least 5 minutes if not closer to 10. How many miles are on your car?
    As a side note, I'm not sure why they would want it in neutral to put on tires.
    In general, I would imagine if the car restarts you're ok, so long as it isn't habitual. I'm no HV battery expert though.
  8. Roger T
    Roger T Member
    198
    48
    MA
    40000 miles now.
  9. Kramah313
    408
    322
    Dallas, TX
    That's about what mine has too. I guess it just shows that many of these places the people don't know anything about hybrids
  10. Roger T
    Roger T Member
    198
    48
    MA
    Just did a simple battery draining test. Drove and charged the battery up to 67.8% SOC. Parked in front of my home. Started up the AC.
    First 5 minutes I had battery current of 3.5 to 4 amps, where AC power is around 600W. For the remaining of the test (10 min) i tried to keep the current at 4.5 to 5.5, where the AC power is at 750 W to 850 W.
    It took exactly 15 minutes to drain the battery from 67.8 % to 39.7 %
    During my initial test i was browsing reddit. Maybe time goes fast when i am having fun lol.
    #10 Roger T, Jul 30, 2016
  11. jeff652
    jeff652 Senior Member
    607
    624
    Idaho
    The dealer is not the only option. We have many customers who have used our Prolong Battery System products to recharge their hybrid battery after an excessive discharge event. It can easily be done at home in a few hours with our systems.
    Kramah313 and WilDavis like this.
  12. Jrlennox74
    Jrlennox74 New Member
    Boston MA
    Every time I take my car to Toyota for oil change I get in my car and the battery level indicator shows 2 bars. I have no idea why this is and I've asked and get back no answer.
    When I go through the drive through carwash and my AC is on, car in neutral, battery needs recharging, a warning comes on the screen saying car can't charge in neutral. Prius c 2013.
    Roger T likes this.
  13. Roger T
    Roger T Member
    198
    48
    MA
    Yesterday I tried draining the battery to 30% in Neutral. No warning message. Did not have guts to drain it further. Regular Prius Gen III.
  14. bisco
    51,155
    without factory specs, you have no way of knowing if the battery is within them or not.
  15. Mendel Leisk
    40,586
    Prius seem to not take kindly to third parties taking possession, just for a few hours. Lots of threads here, regarding installers (window film, audio, etc) and valet service messing up the car. It's not possible/practical to "educate" everyone you're going to hand your car to; something for Toyota to pay some attention to?
    It's like taking your toddler to daycare, and then having to stand there for half an hour, outlining the kid's special dietary needs, the toy they can't be without, their neurosis, and on and on, lol.
    BruceInOKC, jbkendrick and WilDavis like this.
  16. Raytheeagle
    Raytheeagle Senior Member
    11,263
    15,512
    Bay Area, California
    2019 Prius Prime
    Just hope the valet doesn't lose your key and leave you stranded !(. They at least bought another key but led to a long afternoon:(.
  17. Roger T
    Roger T Member
    198
    48
    MA
    I was happy the mechanics did not drain my battery to the point that battery cannot spin up the MG1 to start the engine. :)
    Maybe we have members on PriusChat who drains the battery to 0 in neutral mode. It can drain to 0 in less than 20 minutes if you have the AC on. Maybe some error messages will come up on the dashboard.
  18. Kramah313
    408
    322
    Dallas, TX
    This sounds almost exactly like mine. And mine has similar mileage to yours. So either we're both ok or we're both in trouble :p
    Roger T likes this.
  19. Mendel Leisk
    40,586
    If we're not moving, the car gets shut off. Gotta maintain my fuelly icon.
  20. lar.smith42
    lar.smith42 Active Member
    203
    118
    Double Oak , Texas
    Not sure we are talking about same thing here but here goes. My Prius gets left in neutral with AC running when I am picking up grands or waiting for wife. To hot in Texas to not run AC. When it gets down to 2 bars ICE starts up and charges battery just like it is supposed to. Happens all the time. Don't understand what the problem is here. seriously.
