Battery level
Discussion in 'Prime Main Forum (2017-2022)' started by sonomac, May 12, 2018.
  1. sonomac
    sonomac Junior Member
    25
    US
    I haven't found an explanation of how or why the battery level dips into the reserve area. Is this a problem?
  2. Roy2001
    Roy2001 Active Member
    371
    158
    Sacramento, CA
    it reserves 15% capacity right?
  3. heiwa
    heiwa Active Member
    223
    216
    Central Valley, CA
    bwilson4web and HPrimeAdvanced like this.
  4. a_gray_prius
    2,927
    782
    IL
    It's not the reserve area - that's just the normal hybrid battery that you'd find in any non-prime prius.
  5. jerrymildred
    jerrymildred Senior Member
    11,508
    14,109
    Tampa, FL
    There is no reserve area. The area above the little marks is the area in which the battery has enough charge to let you drive in EV mode and not use any gas. When you use up that charge, that's shown by the level being at or below those little lines and that's where the engine turns on. From that point on until you recharge the battery (either by plugging it it, running it in charge mode or coasting down a big honkin' hill) it drives like a regular Prius.
    I highly recommend some quality time with the manual because there's a lot to learn about this car that's different.
  6. bisco
    49,397
    the battery charge level indicator is not representative of the battery charge, it is how much usable charge you have.
    in reality, the actual charge neither fills or depletes the battery.
    most any aftermarket gauge can show you what is happening behind the curtain.
  7. EyePrime
    EyePrime Active Member
    268
    115
    Ottawa, Ontario, Canada
    2018 Prius Prime
    Lol the manual is like 1000 plus pages. So I just scroll through till I see a picture
  8. HPrimeAdvanced
    HPrimeAdvanced Senior Member
    2,303
    3,519
    Anaheim, CA
    When I first got my Prime, I spent about 5 hours with the owners manual in my lap to answer questions that would come up when I played with the instruments the gauges, everything in the car. Go through all the buttons and switches, and check out the dash warnings (from the graphics in the manual), to help you know all the stuff in the car, and what it can do! You may be overwhelmed, like I was at first, but you certainly won't be bored!!
    AChoiredTaste.com
  9. priuscatprimeguy
    priuscatprimeguy Senior Member
    2,730
    2,640
    Farmington Hills, Michigan
  10. jerrymildred
    11,508
    14,109
    Tampa, FL
    I did the same. I put the manual in my iCloud drive, so it's on my home laptop, my work computer, my phone, and my iPad. I spent at least five hours familiarizing myself with the PiP over several days when I got it. I still look stuff up now and then. And the Prime looks way more sophisticated.
    Better to learn this stuff in the driveway or garage rather than out in traffic. ;)
  11. David Beale
    David Beale Senior Member
    5,963
    1,981
    Edmonton Alberta
    As I said before, by the time I get to the end of the manual, I forgot what was at the beginning.
    One of my friends just got a new 2018 Tech package hatchback model. He brings the manual to our lunch get-togethers. So far there are two or three napkins inserted into important sections for quick referral. ;)
  12. HPrimeAdvanced
    2,303
    3,519
    Anaheim, CA
  13. john1701a
    john1701a Prius Guru
    12,754
    5,245
    57
    Watch this video for detail about what actually happens as you deplete EV and switch to HV mode:
    This is the first half of that drive:
    The gauges in the lower right of the screen providing normally unseen detail are from the phone-app called "Hybrid Assistant".
  14. bwilson4web
    15,513
    SHHHUUUUSSSSHHHHHH!!!
    The index is at the end and they'll skip reading all the good text and sketches.
    #14 bwilson4web, May 13, 2018
  15. HPrimeAdvanced
    2,303
    3,519
    Anaheim, CA
    I know, you've got to eat your meat and vegetables before you can have your dessert! But using index is good in a pinch, after you've perused the "meat" of the manuals!
    AChoiredTaste.com
    priuscatprimeguy and bwilson4web like this.
  16. jerrymildred
    11,508
    14,109
    Tampa, FL
    Great thing about the pdf is that you can just do a search in the reader by hitting cmd-F (or control-F) and type the word you want.
  17. Salamander_King
    Salamander_King Senior Member
    10,970
    8,853
    New England
    As usual, your video is so informative. Thank you for sharing them with us. May I ask where I can find the app "Hybrid Assistant"? Does it work only with Advanced, or does it require some type of OBDII dongle?
  18. jerrymildred
    11,508
    14,109
    Tampa, FL
    Sadly, it's apparently Android only. :( Hybrid Assistant
    Salamander_King likes this.
  19. Salamander_King
    10,970
    8,853
    New England
    Although i don't use it as a phone anymore, I have an old Nexus I can install it.:)
    jerrymildred likes this.
  20. john1701a
    12,754
    5,245
    57
    The app is in Google play store, as mentioned.
    It requires a $60 reader, but is well worth it if you want lots of detail.
    Salamander_King and jerrymildred like this.
