Battery life for very low yearly mileage
Discussion in 'Gen 2 Prius Technical Discussion' started by Tim Hawaii, Dec 13, 2020.
  1. Tim Hawaii
    Tim Hawaii New Member
    Hawaii
    I am thinking about purchasing a used 2nd generation Prius. However I only drive about 1,500 miles per year.
    I do short trips of 4 miles and 7 miles one way. But is seems some people are saying that with my low yearly mileage the battery life will be reduced. I am not concerned about mpg and temperature is not a problem. So does the low yearly mileage affect battery life all other things being equal?
    51,155
    yes, it is a massive problem. if you are not concerned with mpg, why a prius? it is probably the most expensive repair in hawaii
    M in KC likes this.
  3. dbstoo
    dbstoo Senior Member
    1,380
    745
    Near Silicon Valley
    2024 Prius Prime
    XSE Premium
    Unless you are just worried about pollution, that's not a good match for you. A 4 mile trip in a Gen 2 Prius will spend most of it's time with the engine running while it warms up. That will give you about the same emissions and mileage as a Corolla.
    Dan
    M in KC likes this.
  4. mr_guy_mann
    mr_guy_mann Senior Member
    3,966
    1,914
    NJ-USA
    Corolla or Yaris. Gen2 Prius will likely be way more $$ in repairs for the miles used.
  5. Leadfoot J. McCoalroller
    7,861
    7,329
    Pennsylvania
    2018 Prius c
    Lack of use is not going to cause significant extra trouble. The real issue is that the battery is simply going to degrade over time whether you use it or not. The car won't run properly without it, and fixing it will raise the cost-per-mile of owning a Prius over that of most other cars. And if you're talking about 2nd generation cars, those batteries already have degraded. Many of them need battery help today, the rest will soon.
    So, do it if you want to drive a Prius, but don't do this to save money. It would be like buying into the full buffet when you only want a cup of soup: You won't go hungry but you might go broke.
  6. Mendel Leisk
    40,584
    @Tim Hawaii what's your "parking situation"? If you've got secure parking with 120 volt outlets, you can maintain the 12 volt with a smart charger.
    If it's a private garage you've got lots of options, most typical would be an external charger, and a lead running to the battery. That's my scenario; I have the car connected pretty much constantly, using a quick connect that came with my CTEK 4.3. We've been driving as little as once a week, just leave the charger on constantly during down time, no harm.
    In less secure scenario, say a shared underground apartment garage (but still having AC accessible), an on-board charger will do similar duty, where you have the whole charger under the hood, just run an AC cord out through front grill, like a block heater. The NOCO Genius GENM1is a contender I've been considering. Put some electrical tape on your extension cord; hopefully makes it less desirable to thieves.
  7. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,799
    2017 Prius c
    AND....he could charge an EV vehicle too.
    His situation seems to be a perfect fit for EV.
  8. Moving Right Along
    Moving Right Along Senior Member
    700
    546
    At 1500 miles a year, you might want to start asking yourself if it’s cheaper to own a car or just use ride sharing. However, with that said, it seems like your priority in car buying is reliability. According to Dashboard Light, a survey of hundreds of thousands of used cars up for auction, a 2004-2007 Prius has roughly a 12-13% chance of something major failing, and a 2008-2009 Prius has roughly a 5-6% chance of a major problem. Compare that with a Camry, which has roughly an 8-9% rate of major problems from 2004-2013 or a 2004-2008 Corolla with 8-10% major problems. So I’d say a 2008 or newer Prius would be a more reliable vehicle, but if you’re getting an earlier year car than that, go with a Camry or Corolla.
  9. JimboPalmer
    12,470
    6,876
    Greenwood MS USA
    batteries in any car do not like being left off a lot. Any hybrid is a bad match to your driving, Just MNSHO.
  10. edthefox5
    edthefox5 Senior Member
    10,096
    4,831
    Clearwater, Florida
    Do not buy a G2 or G3 Prius.
  11. Tim Hawaii
    Hawaii
    The following is from "The Car Care Nut" a Toyota Master Diagnostic Technician on youtube. As long as the car is driven weekly you should be ok. If it sits for months at a time I would consider a gasoline only car for longevity.
