Battery losing charge while idle
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Georgetown, Nov 18, 2013.
  1. Georgetown
    Georgetown Junior Member
    Hi All
    I just purchased a 2004 Prius. When I am driving the battery seems to work fine but yet the battery loses charge when I am sitting in the car while running on idle. The battery goes down to 2 bars and the engine has to kick in to charge the battery. I have no check engine lights.
    Does this mean my battery needs to be replaced?
    If so then what are your thought on rebuilt batteries
    Thanx for any help!
    walpoleauto likes this.
  2. dorunron
    dorunron Senior Member
    3,318
    1,105
    Houston, TX
    Sounds to me like your Prius is working normally. I think your battery is fine. The ICE (engine) will start up like you described to recharge the traction battery when the computer tells it to. The car will pretty much take care of itself.
    If I was concerned about anything, it might be the condition of the 12 volt auxiliary battery since that does seem to be the weakest point of these cars.
    But to answer your question, I think your traction battery is fine.
    Welcome to Prius Chat!
  3. JimboPalmer
    12,470
    6,876
    Greenwood MS USA
    I think the problem is in bold. Every Prius work this way, they have to. You are not 'idling', the engine is off. Where is the power to run the radio, power steering, AC, headlights, etc coming from? The engine is off, you are draining the battery. (this is normal) When the battery gets low enough, the engine come on and recharges it a little. Once you go back to driving it recharges it some more. How long does all of this take? How many devices do you have turned on?
    So the good news is the only thing wrong is you are unfamiliar with your car. I like John's user guide to help you get familiar fast.
    John's Stuff - Toyota Prius User-Guide (Iconic)
  4. dorunron
    3,318
    1,105
    Houston, TX
    I do agree that the guide mentioned above is very useful. I too have read through that and it helped to explain a lot of things. Also if you have one, take the time to read the owner's manual. I understand it is long and lengthy, but it contains a lot of useful information.
    Due to limits here on Prius Chat, I can not upload the pdf file. You can download it from the link above. It is a little over 8 megs. I definitely recommend you read through it completely.
  5. Georgetown
    Thanx everybody!
    You just made my day! (y) lol
    I have looked at a couple pages of the guide posted and looks like some good reading for a newbie like myself!
  6. uart
    uart Senior Member
    4,220
    1,209
    Australia
    How much accessories were you running Georgetown? Also, what sort of time scale are we talking about here, 2 min, 5 min, 10+ min?
    With minimal loads it should sustain the charge for 20 to 30 minutes before the engine needs to kick in (depending of course on the exact state of charge that you begin with). The more electrical loads you're running though, then the faster it will drop of course. Aircon is by far the biggest factor, that can drain the charge relatively quickly once the engine is stopped.
    One final thing to watch for. Make sure you keep your foot firmly on the brake pedal (unless you shift to "P"), otherwise it draws continuous motive power. You will know if your foot is on the brake firmly enough if the arrows on the energy monitor screen disappear. Some people make the mistake of applying the park brake and then removing their foot from the regular brake pedal. If you want do this then you should also shift to "P".
  7. Georgetown
    Thats the thing. It will drop in minutes!
    I admit that I always have the ac on and I will give you an example. . . I pulled over to talk to a friend and had the headlights, AC, and radio on while my foot was on the brake pedal and within 5 minutes it went from two lines to the top to two lines from the bottom. But yet I drive and battery charge jumps back up to blue and then green.
    I am going to test it and time it with the ac and radio on and without.
  8. Patrick Wong
    18,200
    6,493
    The radio is not an issue as it takes very little power.
    The air conditioning compressor takes a tremendous amount of power while the headlights consume a moderate amount of power.
  9. uart
    uart Senior Member
    4,220
    1,209
    Australia
    It's the aircon. Try it some time with the aircon off and it will drop much more slowly.
    BTW. You can set to Prius aircon to draw a lot less power if you want to set the temperature up higher like 75F to 80F.
  10. Georgetown
    Temp is on 69
    I love my ac ! lol
  11. dkelly
    dkelly Member
    118
    Gilbertsville, PA
    I've found if you really want to drain your battery quickly, stop on a slight uphill and, instead of using the brake to keep you stationary, apply just enough accelerator to hold the hill. Nothing seems to be happening, but the battery state of charge drops really fast.
  12. dorunron
    3,318
    1,105
    Houston, TX
    That is why the battery is losing it's charge so fast. Try 74 or 76 and you will see the difference. ;)
  13. walpoleauto
    walpoleauto Junior Member
    48
    Walpole, Massachusetts
    Your Prius sounds perfect. If you have any serious issues, your dashboard should light up like a Christmas tree.
  14. Former Member 68813
    3,524
    983
    US
    Congrats on the purchase. How many miles/km?
  15. Britprius
    Britprius Senior Member
    5,194
    1,918
    Herefordshire England
    Doing this is really bad for MG2 in the transmission.
    You are putting electrical current into the electric motor without any rotation. All the energy put in only produces heat. this can be several KW. The heat cannot be removed quickly because the cooling oil is also still, and the top part of the motor windings are not submerged in oil having no cooling at all. This can rapidly lead to motor burnout.
    John (Britprius)
  16. FreydNot
    FreydNot Member
    216
    37
    Seattle, WA USA
    It would be much better to set the AC to MAX COLD and let the electric compressor consume the HV battery energy.
  17. john1701a
    john1701a Prius Guru
    12,797
    5,280
    57
    I remember seeing that on a regular basis with my 2004 Prius. Photo shots would take 30 to 45 minutes, sometimes longer. The car wouldn't move in some cases, especially for the sunset opportunities. The system and headlights would be on the entire time.
    I'd see the battery down to 2 bars then. It was no big deal. Watching it recharge was though. I found it fascinating how quickly that capacity was recovered, while still delivering hybrid efficiency.
    In short, it's doing what it is suppose to. The battery should be fine.
  18. bisco
    51,154
    did you ever look into a rebuilt battery pack?
