Battery low + brake ABS traction lights
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Air0ne, Jan 20, 2020.
  1. Air0ne
    Air0ne Junior Member
    Montréal
    Hi there,
    A week ago, after a day of rain, I got brake (yellow and red), traction and ABS light ON. As I figured out that the fuses cover was not well closed, I checked some of the fuses related to ABS and 2 or 3 days later, the lights went OFF.
    2 ago, the lights came back so I checked my battery voltage. I got 11,93v cold (minus 20 degrees) and 12,35v after my ride to the subway (10 km long).
    Is the battery the problem?
    Thx for your help guys
  2. Ed Beaty
    Ed Beaty Active Member
    334
    309
    Salt Lake City
    "Is the battery the problem?"
    Very likely. How old is it. Even a post-drive 12.37 is marginal to poor; 11.93 resting...a goner.
    dig4dirt likes this.
  3. dig4dirt
    dig4dirt MoonGlow
    1,150
    741
    Lancaster Co PA
    2014 Prius c
    Yep, time to replace. If original (10 years), no more questions, your honor.
    Ed Beaty likes this.
  4. Air0ne
    Montréal
    In that case, why is there no specific light for the battery? Back in time, it was common to have those lights no?
    mjoo likes this.
  5. Grit
    Grit Senior Member
    6,147
    4,057
    Wilkes Land
    Also were engine temp read outs, battery voltage reading, oil pressure levels and etc.
  6. bisco
    49,474
    a mistake by toyota, i think gen 4 gives a warning.
  7. mjoo
    mjoo Senior Member
    1,124
    1,316
    Michigan
    Toyota saving $1 per car
    Pixel XL ?
  8. Air0ne
    Montréal
    Battery swapped. Lights gone. Looks like it was the battery folks!
    Raytheeagle, dig4dirt and bisco like this.
  9. bisco
    49,474
    Well done!(y)
  10. Priuslover09
    Priuslover09 Member
    365
    48
    Dc
    Hi
  11. bisco
    49,474
    hello!
    dig4dirt and Priuslover09 like this.
  12. Air0ne
    Montréal
    Hi there,
    With my new battery, the voltage is 12.58. Is it normal or is the garage tried to give me a refurbished one? What a brand new battery is supposed to give me?
  13. Air0ne
    Montréal
    Ok... Lights are ON and OFF so I bought a scanner. I got C1238 / C1253 and C1466. When I went to the mechanic, he told me that my rear Left wheel was jammed and that the brake needs to be cleaned.
    Can I have your opinion guys?
    Thx
  14. dig4dirt
    dig4dirt MoonGlow
    1,150
    741
    Lancaster Co PA
    2014 Prius c
    Those codes point to wheel speed sensor and other related parts.
    I would plan on getting brake lube and looksee done, perhaps other brake work if needed
    the mechanic sounds like he is correct.
    Pay attention to the rear brake caliper slide pins too. they tend to rust up on the rear for Gen3
  15. Air0ne
    Montréal
    Hi guys,
    The rear right wheel bearing was dead and needed to be changed. No more errors on the dashboard so far.
    Fingers crossed
    Thx guys
