Battery Low
Discussion in 'Gen 5 Prius Main Forum' started by Argyros, Nov 27, 2023.
  1. Argyros
    Argyros Member
    225
    133
    2023 Prius
    Hey all,
    This long weekend, we were doing a bit of driving, mostly local, when on Saturday, I attempted to put my LE into EV mode to get more mileage; well, imagine my surprise when on the display it read 'EV mode not available; battery low'.
    Not sure how it got low like this, but also not sure what to do to get it back to the mid-level charge where it's supposed to me; I've been driving on ECO, and subsequently getting @ 52 MPG in mixed highway driving.
    I do have an appointment next weekend at service for a 'pre-first 1000 mile oil change' (I saw a very informative video on why this was necessary), and will bring it up if there's no good answer on the forum.
  2. BiomedO1
    BiomedO1 Senior Member
    1,476
    797
    SacTown, Ca
    That's normal for a non-plugin Prius. In auto/Eco mode, the ECU will go as far as it can in EV mode, before firing the ICE. Try to force the car back into EV mode won't work; the ECU is protecting the battery pack from getting damaged and too low. Once the battery reaches 1/4 to the halfway point, it'll allow you to switch back to EV mode.
    Hope this helps....
  3. Mendel Leisk
    38,728
    Unless there's been a drastic change for 5th gen, I'd reserve EV for driveway shuffles and the like. With our 3rd gen even that's not possible with a stone-cold engine, unless I spoof it with at least an hour of block heater plugged in. That's something I've taken to doing, say I want to move the car (with cold engine) from garage to driveway/street.
    Trollbait likes this.
  4. fuzzy1
    10,170
    That is just the way it works in some driving conditions, especially when lots of low speed ICE-off conditions are encountered, such as low speed city or residential streets. These drain the battery without much ICE-on time to refill it. If they continue long enough, the ICE will be forced on.
    Steady flat highway speed conditions are usually very good for getting the charge back up to 'normal'.
    Putting the car into EV mode is generally not an effective way to improve MPG, other than in certain conditions such as parking lot movements when the engine is cold and your movement will be short enough that the ICE won't be needed, so EV can be used to avoid an engine warmup cycle.
  5. bisco
    49,500
    if you want ev mode, trade for a prime
    fuzzy1 and Trollbait like this.
  6. Argyros
    Argyros Member
    225
    133
    2023 Prius
    I didn't say I wanted EV mode, I was going low speeds and was wondering; I was just asking about the battery level. Some people on this forum can really be judgmental and a bit not nice at times. I will just ignore that, call it out, and appreciate the people here that actually help with the questions. That's what we're here to do; help. Thank you Mendel and Biomed.
    Gokhan likes this.
  7. bisco
    49,500
    i was trying to be helpful. putting your prius in ev mode costs mpg's and reduces the life of the battery to some extent.
    take it as you will, no offense intended
  8. Gokhan
    Gokhan Senior Member
    4,656
    1,866
    Paramount CA
    The amount of charge in the HEV battery will greatly vary as the car switches the ICE on and off. If you were already at the bottom charge level, then the EV mode won't be available.
    This is what I like about the Prius Prime—you will always have the EV mode available as long as you keep an eye on the state of charge. I find the EV mode very useful for short trips. I only use the HEV mode for long trips over fifteen miles. If you deplete the EV reservation and reach the bottom of the HEV reservation in the Prius Prime battery, then it becomes a regular Prius, and you may have the same "EV mode not available" blues. It actually displays the exact same message when that is the case and press the EV/HEV button.
  9. Trollbait
    11,561
    You stated that you tried putting in EV mode, got the warning, then asked how to get the charge of the battery up.Thinking you want EV mode from that isn't much of a leap.
    Earlier generations didn't display reasons for why it didn't go into EV when asked; it simply didn't. The manual had a list of possible causes. It also explained the purpose of EV mode was for parking spot shuffling, and to avoid disturbing neighbors with engine noise. The gen1 and gen2 for the first few years cause Toyota was likely worried people would misuse it, and they didn't want to field complaints about it.
    As for your first question about the charge, don't worry about it. The system program will charge the battery up in a manner as efficiently as possible without outside input. Toyota has a lot of experience in keeping hybrid batteries in good shape.
