Battery maintenance
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by nicoj36, Sep 5, 2022.
  1. nicoj36
    nicoj36 Active Member
    518
    162
    I only drive my Prius 3-days a week, Friday, Saturday, and Sunday. It sits on the driveway 4-days a week, Monday through Thursday. Is this okay or do I need to get a battery-tender? Also, is there a way to connect a battery-tender under the hood? Using the jump terminal in the fuse box? Thanks!
  2. Mendel Leisk
    40,574
    Some chargers come with quick-connect wiring, which you can use in place of the alligator clips. They’re more convenient and secure. Here’s where to connect positive at the under hood fuse box:
    For neg you have lots of options.
    our useage is very infrequent and I have it on charger all the time it’s sitting.
    nicoj36 likes this.
  3. CR94
    CR94 Senior Member
    2,664
    1,152
    Northwestern S.C.
    The battery shouldn't lose much charge in only 4 or 5 days. In rough numbers, 0.02 amperes standby drain × 100 hours = 2 ampere-hours, vs. about 40 ampere-hour capacity of your battery. Why bother with the tender?
    nicoj36 likes this.
  4. PriusCamper
    PriusCamper Senior Member
    12,048
    4,892
    Pacific Northwest, USA
    In general the people who drive their Prius everyday can go way longer before hybrid battery pack fails. People on here who have multiple Priuses (so they aren't driven every day) have replaced their hybrid battery early under warranty. So it's something to plan for happening sooner than later. And because OEM Toyota hybrid packs are hard to find due to supply chain issues you might want to upgrade to a project lithium pack before they run out. They just launched their pre-order for a last small batch of the year and if you use my affiliate link to buy I'll provide unlimited online tech support: https://projectlithium.com/?ref=9qLPw
    nicoj36 likes this.
  5. ASRDogman
    ASRDogman Senior Member
    7,232
    3,774
    How long is it on? 10 minutes? 1, 2, 3, hours? How old is the battery?
    If you don't drive long, you should check the voltage maybe once a month?
    If it's getting low, put a 4 amp or lower charger on it on one of your days off
    every 3 or 4 weeks.
    Better to be safe than sorry. You may go out there and it won't start one day.
    Then you'll have to jump it, and if you don't drive it long enough for the hybrid battery/inverter
    to charge it back up, you'll just have the same problem.
    If you drive for an hour or so that should be enough to keep it topped off.
  6. Albert Barbuto
    102
    96
    Northeast USA
    Hybrid pack will be fine for this short period of rest. Your 12v battery will have a longer lifespan if kept fully charged 24/7. Sulfation starts when a lead acid battery is not in a fully charged state. I would use a tender...
  7. nicoj36
    518
    162
    Its driven 100 miles a day and at least 2 hours per day
  8. ASRDogman
    7,232
    3,774
    Then the battery should be fine. You haven't had a problem so far.
    #8 ASRDogman, Sep 6, 2022
    jzchen and nicoj36 like this.
  9. Doug McC
    Doug McC Senior Member
    1,044
    396
    Midwest
    2022 Prius
    Just check the voltage with a multimeter occasionally to get a feel for how low it gets. If you are comfortable with it, don’t worry about it. Mine sits like that and is fine (which is exactly what Toyota says in my owners manual).
    Regarding the hybrid battery, Toyota states in my owners manual that it will be fine, especially with your use.
    nicoj36 likes this.
  10. nicoj36
    518
    162
    Whats your experience with the aftermarket lithium battery? Stronger than OEM? Better range and power like a PIP?
  11. PriusCamper
    12,048
    4,892
    Yes, all of the above... In few weeks I will have had the Project Lithium protoype pack in my car for two years! This time of year I like it because Air conditioner works a full capacity because the computers sense plenty of amps still available from the battery pack. And on road trips climbing mountain passes I'm no longer in the slow lane with one bar, but in a faster lane with 3 bars of power still available.
  12. AzusaPrius
    AzusaPrius Senior Member
    2,137
    900
    Im sure the OP was asking about the 12v.
    No one needs to put a battery tender on the HV battery.
    Having a bad 12V especially in this heat will also drain the HV battery more as it sits unused.
    If its an old 12v then replace it.
    As far as another HV battery, well there is nothing better than Dr. Prius Lithium pack.
    I have been using it for 2 years and I live in the high desert with high temps.
    The AC does work better and I remember noticing that when I first installed it.
    Also it is lighter than any HV pack.
    I can sit in this heat for over 30 minutes before the ICE kicks on to charge it.
    The lithium pack also charges up very fast.
    Check out my profile for helpful links.
    #12 AzusaPrius, Sep 8, 2022
    PriusCamper and nicoj36 like this.
  13. nicoj36
    518
    162
    @AzusaPrius @PriusCamper
    Was the install pretty straight forward? Is it plug and play or do I need to calibrate it with an OBD? I’ve cleaned the HV fan before.
  14. AzusaPrius
    2,137
    900
    No different than other videos about changing out the modules.
    Just have to know what you are doing.
  15. PriusCamper
    12,048
    4,892
    Yes
