Battery module matching service
Discussion in 'Gen 2 Prius Main Forum' started by Adebrettski, Oct 24, 2020.
  1. Adebrettski
    Adebrettski Junior Member
    Seattle
    Currently playing whack a mole... Was thinking, is there anybody who offers a service where I could send them a module and they could load test it, and send me back modules that match it for strength? Thinking it could save some time + money vs just buying random ebay modules and hoping for a match. I need 8 for my pack.
  2. Adebrettski
    Seattle
    Maybe I could do a load test with specific variables on my end also, cut out the need to send a test module
  3. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    There are companies that will sell you 28 "balanced" modules. But I have never seen a company match a random module. It is much easier to buy 28 modules for yourself and then resell the others if you're intent on playing whack-a-mole.
    Adebrettski likes this.
  4. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,093
    Columbia, SC
    Is your intention to replace the modules with no cycling of the remaining modules? Or will you be performing 3+ cycles of each module?
    If you plan to cycle them using a hobby charger, you can use the data to get an average capacity of the good modules. If you cycle them, use a 1.5 amp discharge and 2 amp charge. I have hundreds of modules available that have been cycled using those setpoints and each module has it's capacity documented on it. It would be easy to match up.
    Testing just one random module is risky, as there is no guarantee it's capacity will be even close to the other modules
  5. PriusCamper
    PriusCamper Senior Member
    13,035
    5,298
    Pacific Northwest, USA
    I'm an hour south of you and could do something similar of that. Processing modules is a small community effort down here. And I'm more interested in helping/having lasting friends than ripping people off, so hit me up...
  6. Prodigyplace
    12,668
    11,828
    Central Virginia
  7. PriusCamper
    13,035
    5,298
    While this is helpful in theory... In practice most healthy modules that are a decade or older don't show much detectable difference unless they're starting to fail.
    In my experience the greatest difference in used moduels is if they've been reconditioned or not. A healthy reconditioned module, which is primarily what people sell doesn't do well in a pack that hasn't been reconditioned yet because it has much more capacity than un-reconditioned modules. So as the pack drains while climbing a hill for example the red triangle may show up due to reconditioned module holding a higher voltage than rest of pack.
    #7 PriusCamper, Oct 25, 2020
    tangerino likes this.
  8. Adebrettski
    Seattle
    that sounds great, messaged.
  9. Adebrettski
    Seattle
    ive been cycling and rehabbing, but from the ebay modules ive found and the ones in my pack, it seems like aH capacity doesnt necessarily correlate to performance on a load test... i have much higer capacity modules that drop significantly more than less capacity modules and are throwing block weak codes, which from what im reading isnt uncommon, sounds like load test is the most determinant of modules playing well together
  10. kenneth winter
    kenneth winter Junior Member
    38
    tn
    Do you have any 6200 or greater Mil Amp modules for sale?
  11. TMR-JWAP
    6,404
    6,093
    Columbia, SC
    @kenneth winter
    If you were asking me, yes, I do. What is the first 4 digits of your serial numbers? I can see if I have close date matches with that desired capacity.
    Prodigyplace likes this.
  12. kenneth winter
    38
    tn
  13. TMR-JWAP
    6,404
    6,093
    Columbia, SC
    @kenneth winter
    I think I have what you need. The information below is from a battery that had 28 modules with date code 17XJ which is October 17, 2008. Yours are date coded 097J which is July 9, 2008. Unfortunately, my laptop is coming up with an error code every time I try to open any MicroSoft Office files, so my excel sheets with the data aren't available right now. After cycling a pack, I put small stickers on each module documenting it's capacity. First number is capacity from the sticker, second number is the current voltage of the module (as of about 1pm today). These modules were cycled during Fall of 2020 and then put on a shelf. All 28 are still clamped in an OEM assembly. Pick which ones you want. One year guarantee, $30 each + $15 for a USPS Medium Flat Rate box that can hold up to 8 modules.
    6068mah--7.59v
    6369--------7.66
    6151--------7.67
    6145--------7.67
    6313--------7.66
    6409--------7.66
    6095--------7.67
    6278--------7.66
    6309--------7.66
    6436--------7.66
    6084--------7.66
    6279--------7.66
    6240--------7.66
    6390--------7.65
    6196--------7.66
    6460--------7.66
    6208--------7.66
    6401--------7.65
    6260--------7.66
    6107--------7.66
    6056--------7.66
    6420--------7.66
    6337--------7.66
    6370--------7.66
    6140--------7.66
    6329--------7.65
    6098--------7.65
    6067--------7.59
  14. kenneth winter
    38
    tn
    These two please..
    PM for shipping and payment details..
    Kenneth WInte
  15. TMR-JWAP
    6,404
    6,093
    Columbia, SC
    @kenneth winter
    The PM (start a conversation) function hasn't been working correctly (at least for me) for months. If you click on my user name, it should show you my mobile number. That number is linked to one of my paypal accounts.
  16. kenneth winter
    38
    tn
    I have been texting your number?
  17. kenneth winter
    38
    tn
    number corrected...
