Battery Not Fully Charged
Discussion in 'Gen 5 Prius Main Forum' started by ToyotaFamily, Aug 5, 2023.
  1. ToyotaFamily
    ToyotaFamily New Member
    Griffin, GA
    2023 Prius
    I don’t have a Prime so have not seen this Q asked for the XLE trim line. I have had my Gen5 for a week and regularly check to see how full the battery is. No matter what I do each day driving wise I continue to see that the battery is three bars short of full. What can or should I do to make it fully charged?
  2. Tideland Prius
    16,155
    So you have a regular Prius?
    It won’t be full under normal driving for longevity reasons. Toyota typically keeps the battery near 60% SOC (true SOC). The top buffer is there in case you go down a long or steep hill so that you can take advantage of regen before the battery fills up.
    Once full, the car will actually actively bleed the excess charge. (Usually 1 bar or less).
  3. ToyotaFamily
    Griffin, GA
    2023 Prius
    Thanks for the explanation. I feel like the “red headed stepchild” in this Forum since it seems like everyone has a Prius Prime!
    bisco and Tideland Prius like this.
    49,492
    normal. you only see full in special circumstances
  5. Tideland Prius
    16,155
    No worries. This forum exists to learn from one another!
