Battery overcharge on Braking
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by chryguy, Apr 19, 2023.
  1. chryguy
    chryguy Junior Member
    Joliet,IL
    Howdy all,
    Long story short.
    Getting the "Red Triangle of Death"
    I'm using Carista to reset the RTD. I'm using Dr Prius to monitor my batt.
    Every time I apply the brakes my traction battery charge spikes upward of 250v...
    This is happening w 2 different traction batteries.
    Any suggestions would be appreciated.
    Thanks in advance
    CG
    Tombukt2 likes this.
  2. ChapmanF
    17,334
    More interesting than the voltage would be the charge current. Could you post what that's doing?
    Even better would be to post that and also the battery state of charge (SoC).
    Have you used either Dr. Prius or Carista to find out what the trouble codes are behind the warning triangle before you reset it? If you post those codes here, we can be more help.
  3. chryguy
    Joliet,IL
    I took a couple screen grabs...
    #1 Pack voltage was 252.6 voltage
    Charging was 14.32 amp
    State of charge was 30.00%
    Max charge 26.8
    #2 Pack voltage 252.3
    Charging 13.19 amp
    State of charge 49.00%
    Max charge 26.8
  4. chryguy
    Joliet,IL
    P0A80 is the reoccurring battery code
  5. Tombukt2
    Tombukt2 Senior Member
    12,197
    2,150
    Durham NC
    So when you're swapping these two battery packs in and out of the car are you looking under the silver cover sensors nuts ECU plug all things like that come to mind take a picture maybe and looking for frosted nuts black bus bars it should be copper or silver hard metal etc sensor wiring that's not copesthetic broken etc ECU battery ECU plug corrosion and wiring issues etc seems to me I wouldn't be having the batteries going in and out of the car without looking under the hoods of the said batteries.
  6. ChapmanF
    17,334
    There's nothing excessive about a 13 or 14 amp charge rate applied to a battery that's 30% or 49% charged.
  7. chryguy
    Joliet,IL
    Howdy,
    Drove it today, I've got more.
    P3020
    POA7F
    P3013
  8. ChapmanF
    17,334
    P0A7F and P0A80 are set according to two different ways of measuring a battery's health, but they seem to have reached the same conclusion about this battery.
  9. chryguy
    Joliet,IL
    Howdy,
    Ok, here's just part of "the long story"...
    I have 2 2nd gen Prius's, thus why I have 2 batteries and also an empty battery chassis. I refer to them as P1 and P2. I also have a "parts Prius". That makes 3.
    I have had both batteries completely apart.
    I have reconditioned the individual cells w the charge/discharge cycle at least 3 times for each cell. That would be 28X2.
    I have load tested all the cells in this battery(this is P2's battery)
    All of the battery terminals(each cell), all of the nuts, and all of the buss bars have been cleaned.
    At this point all of the plugs I have looked at are corrosion free. I will check all the rest of them tomorrow.
    Thanks for your help and ideas
    CG
  10. chryguy
    Joliet,IL
    Howdy,
    Sorry for the novel...
    P1 has come to that same conclusion about both batteries, thus why I'm wondering what is going on.
    P1 threw P0A80 with it's own battery, and Dr Prius showed module 3 was the only one underperforming.
    I pulled P1's battery and checked cell voltages.
    One of the cells(module 3) was was lower than average (8 volts). it was 7.4 volts.
    I will check individual cell voltage in this battery tomorrow when I pull it out.
    Thanks for your time and assistance, and feel free to ask questions if I'm not being clear.
  11. ChapmanF
    17,334
    Maybe that's an overinterpretation of the values Dr. Prius was showing?
    The car's judgments for P0A7F and P0A80 involve more than snapshots of voltages.
    I wonder if you might just be running up against the limits of reconditioning. Many people do seem to report some improvement, but few report that it's completely effective or can be kept up indefinitely.
  12. Tombukt2
    12,197
    2,150
    Durham NC
    Folks like the hybrid Doctor that have skin in the game of the EV battery business can make reasonably short work out of the whack-a-mole and all the nonsense that we have to do in our carports or whatever we're doing hobby charging single cells etc etc I mean seriously that's for somebody that their time is invaluable to them or to everybody I don't know That's a lot of time breaking down three batteries charging up three sets of modules racking them back up cleaning bus bars and nuts without a tumbler or anything like that My goodness nah seems pound foolish to me but that's that so far every battery I've had rebuilt by people like the hybrid doctor that are in the game to win so far are doing quite well I've got almost 2 years on one without any problems. Now I'm not here trying to wear them out and run massive tests on them every day either I'm just driving my car minding my business and running my service calls which is about 3 to 600 mi a week generally speaking so we are driving the cars
  13. chryguy
    Joliet,IL
    Howdy,
    I have also wondered if these are "worn out", but...
    I know a retired electrical engineer who told me as long as the battery cells meet or exceed specifications they should be fine to reuse.
    When I got P1 5 years ago I was given the receipt for the fresh $1800 remanned battery that was in it. It had a 90 day warrantee. It lasted 2 years. I contacted the rebuilder, they said sorry.
    I looked online, and fixed it myself.
    It has been over 2 years this time.
    I do use small digital chargers for individual cell charging.
    I also have a larger pack charger, and a stress tester.
    Thanks for the help and advise
    CG
  14. AzusaPrius
    AzusaPrius Senior Member
    2,137
    900
    You may want to check your brake pads.
    When was the last time you serviced the system with new brake fluid?
    The pack can take the current just not for a long time.
    You could press harder on the brakes so not to overcharge the battery using the regen.
  15. sabinashakya
    sabinashakya New Member
    Nepal
    2016 Chevy Volt
    The "Red Triangle of Death" is a warning indicator that appears on some Toyota and Lexus hybrid vehicles, indicating a problem with the hybrid system. It's important to address this issue as soon as possible, as it can lead to further damage to the vehicle if left unresolved.
    Regarding the spike in traction battery charge when applying the brakes, this is not a common issue and could potentially be caused by a faulty regenerative braking system. The regenerative braking system is responsible for converting the kinetic energy of the vehicle during braking into electrical energy to recharge the traction battery.
    I have a Chery Tiggo 4 Pro.I would recommend consulting with a qualified mechanic or hybrid specialist to diagnose the issue and determine the appropriate course of action. They may need to perform further diagnostic tests using specialized equipment to identify the root cause of the issue.
    In the meantime, I would recommend avoiding heavy braking and driving at high speeds until the issue is resolved. It's always better to err on the side of caution when it comes to hybrid vehicle issues.
    #15 sabinashakya, Apr 21, 2023
  16. ChapmanF
    17,334
    The first post presented pack voltage, not SoC or charge current. Those were presented in a later post, and 13 or 14 amps charge current at 30% or 49% charge really aren't anything to hang the word 'spike' on.
