battery power
Discussion in 'Gen 3 Prius Fuel Economy' started by nizora, Apr 21, 2010.
  1. nizora
    nizora New Member
    australia
    Could amy member please advise me how many miles could I travel under battery power only ( assuming battery is fully charged and travelling speed at or under 30 miles per hour) before the battery is exhausted.
    many thanks, Rob
  2. djasonw
    djasonw Active Member
    950
    116
    Coconut Creek, FL
    I would say the most you could travel would be 2-3 miles. Since your vehicle is a 2010 they changed the software to be more conservative so I may be off a bit. With my 2004 I know I can go at least 2 miles @ 30 MPH. Bottom line, I doubt you'd go further than 3 miles. Even though the battery still has juice it is protected by the software to prevent it from going below a certain threshold. This preserves battery longevity.
  3. nizora
    nizora New Member
    australia
    Thanks for the information, much appreciated!
  4. hsiaolc
    hsiaolc New Member
    617
    46
    UK
    Depends greatly on traffic. If you are stuck in traffic with air con on then you won't have much miles before your battery is depleted.
  5. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    Another way to think about it is that your HV battery contains about the same usable power as three tablespoons of gasoline.
    Tom
