Battery Problem?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Taz43, Mar 6, 2020.
  1. Taz43
    Taz43 Junior Member
    47
    Los angeles
    Can someone pls tell me what these 3 pics of the HV battery tells me. 1st pic with green bars is in idle, 2nd with yellow bars is driving, and 3rd is just another app for reference.
    Thank you Screenshot_20200306-120150_Dr%20Prius.jpeg Screenshot_20200306-131056_Dr%20Prius.jpeg Screenshot_20200306-131607.jpeg
  2. Taz43
    Taz43 Junior Member
    47
    Los angeles
    1st is while driving and 2nd is in idle.
    Any help appreciated. Thanks in advance. Screenshot_20200306-190437_Torque.jpeg Screenshot_20200306-185628_Torque.jpeg
  3. ydpplqbd
    ydpplqbd Active Member
    542
    250
    Posting #2 looks like two ("2") screenshots of Torque Pro which is what I use. First screen shot in posting#2 lacks "HV Charge" and "HV Fan Speed". However both screenshots have "HV SOC". First screenshot shows HV SOC at 66% while second screenshot shows SOC at 44%.
    Both screenshots show HV Block1 being about 6/10V lower than the rest of the cells. Looks like there is an issue with HV Block1. I have not rebuilt a HV battery pack yet but HV Block1 appears to be the first issue arising.
    Has mpg or performance been affected by HV battery issues?
    #3 ydpplqbd, Mar 7, 2020
    Taz43 likes this.
  4. ericbecky
    ericbecky Hybrid Battery Hero
    4,371
    3,220
    Madison, Wisconsin
    You will need to deal with block 1.
    It is acting much differently than the rest.
    Taz43 likes this.
  5. Taz43
    Taz43 Junior Member
    47
    Los angeles
    I an still averaging 53mpg and no issue driving what so ever. I got that dreaded check engine and red triangle. Am I ran all these test to see what's wrong. Anyways the dash signs went away and it drives fine, bit I opened everything up to clean the HV Fan and now I figured if I need to change a module, I might as well do it now.
    What you guys think, should I just go ahead and change the 1st module and get something that comes out to around the other modules, maybe off by .01 or .02
    This way I wouldn't need to worry about equalizing it. You guys have more experiance, pls share your thoughts.
  6. Taz43
    Taz43 Junior Member
    47
    Los angeles
    also I'm not quiet sure what to make out of the internal resistance on the bottom of the pic on post #1, do i need to be concerned about those as well?
