Battery problems in my new used Prius?
Discussion in 'Newbie Forum' started by chickade, Dec 13, 2010.
  1. chickade
    chickade New Member
    Pennsylvania
    2001 Prius
    I
    Hello- We bought a used Prius for my daughter, and paid good money- probably much more than we should have at a dealers, and now the Prius is having problems starting when my daughter leaves the lights on with the engine off for only a few minutes. Later, the battery seems to get charged up again and the car will start.
    The car is still under warranty but I'm afraid that if the problem is the battery, the dealer with do a quick fix that will last a few months and we will be stuck with replacing the entire battery. What would you suggest?
    Thanks for your help. The dealer is in Springfield PA.
  2. jdenenberg
    jdenenberg EE Professor
    3,852
    1,845
    Trumbull, CT
    2020 Prius
    LE AWD-e
    This is only the little 12v battery that is used to turn on the electronics. It should not cost more than $200 (although there are limited purchase options - a Toyota dealer or a particular web site Elearnaid,com). The big Traction battery is not involved in your difficulty turning on your Prius.
    JeffD
  3. xpcman
    xpcman Senior Member
    1,302
    295
    California - SF Bay area
    You have two batteries in the Prius. The traction battery that drives the wheels, starts the engine and a 12 volt battery that powers the lights and accessories. The 12 volt probably needs replacing and is marginal in the cold weather. The 12 volt battery needs to supply enough power to get the computer controls running. Then the traction battery can start the engine. The bad news is it's a special battery size that needs to be bought from Toyota. It might cost $200 to replace.
  4. firepa63
    firepa63 Former Prius Owner
    1,761
    208
    Replace the 12v battery...
  5. ursle
    ursle Gas miser
    1,049
    192
    NH
  6. don_chuwish
    don_chuwish Well Seasoned Member
    816
    182
    Southern Oregon
    The used Prius is a 2001, as specified in your profile? Not sure if the eLearnAid Optima works, best double check.
    Short of a new battery, buy, beg, borrow (don't steal) a good battery minder type charger. BatteryMINDers.com or Griot's Garage - Battery Manager IV are good options.
    Let them work on the battery overnight and see how it goes after that.
    - D
  7. richard schumacher
    7,663
    1,038
    United States
    If your daughter has the battery replaced it should help her remember to turn off the lights.
  8. ozarkgolfer
    ozarkgolfer Junior Member
    76
    Rogers, AR
    How long have you had possession of this vehicle? What does the warranty include and how long dos it extend?
  9. KK6PD
    KK6PD _ . _ . / _ _ . _
    4,003
    944
    118
    Los Angeles Foothills
    Go find an Optima Yellowtop, NOT the REDtop, battery.
    ASAP!!!
    Enjoy the car!!
  10. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
